Author Topic: How do I find grounds  (Read 1242 times)
LoyalistRevolt
  • Last login:June 19, 2008, 08:52:07 am
  • SEGA!
« on: March 13, 2008, 08:12:15 pm »
How do I check to see if something is a ground connection or a hot?
Not posting doesn't make you a noob, ignorance, stupidity, laziness, and talking trash make you a noob.
Just cause I don't post in threads doesn't mean I don't read the threads...
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
Re: How do I find grounds
« Reply #1 on: March 13, 2008, 08:15:10 pm »
In my VERY little experience (1 cab), Green wires are ground.
LoyalistRevolt
  • SEGA!
« Reply #2 on: March 13, 2008, 08:16:50 pm »
I meant on a controller hack and such
CheffoJeffo
  • Cheffo's right! ---saint
  • Last login:July 14, 2025, 12:11:49 pm
  • Worthless button pusher!
« Reply #3 on: March 13, 2008, 08:17:58 pm »
OK, before we go too far ...
What is the context of the question ?
Are you talking about mains (e.g. AC) power ?
Or are you trying to figure out why your controller isn't working and you think you have a bad common ground ?
EDIT: Already answered ... the reference to HOT threw me and I had visions of someone sticking a controller hack into an electrical socket!
Working: Not Enough
Projects: Too Many
Progress: None
LoyalistRevolt
  • SEGA!
« Reply #4 on: March 13, 2008, 08:20:34 pm »
Well I have this madcatz dreamcast controller and no one has the soldering points for that one so I need to find out where the hots are and before anyone post this site It is not the same type of controller as this http://www.darkravenwind.com/cdvision/madcatz.htm
ps. They are right next to each other I just don't know which is which
brack
  • TIGHTEN YOUR BITS!
  • Last login:March 26, 2012, 09:05:31 pm
« Reply #5 on: March 13, 2008, 08:59:40 pm »
Any board I've ever seen has lines you can trace from the buttons.  If you look closely enough the ground sides of them are usually connected to each other.
ArcadEd
  • Last login:March 04, 2012, 01:25:15 am
  • Arcade-In-A-Box , Relive Your Childhood
    • Arcade-In-A-Box
« Reply #6 on: March 15, 2008, 12:00:06 am »
BINGO to what Brack said :).
Look at the traces.  There will be one that goes to one side of every button area.  That is your common ground.  The other side of that button is the "hot" in this case.
I'm about to solder up two of those exact same pads, so if you need help let me know.
danny_galaga
  • Last login:September 08, 2025, 05:14:57 am
    • dans cocktail lounge
« Reply #7 on: March 15, 2008, 08:09:37 am »
best not to refer to it as 'hot'. thats more a mains term. you alarmed a few of us...
LoyalistRevolt
  • SEGA!
« Reply #8 on: March 15, 2008, 11:56:30 pm »
The strand connect in the middle of the point.....What do I do now :dunno
