Author Topic: Electrohome G07-CB0 Mirroring  (Read 2094 times)
ncflagg
  • Last login:October 25, 2025, 08:49:13 pm
  • Oh, yeah. Idaho IS right next to Iowa.
« on: March 11, 2008, 12:29:09 am »
I've been working on this G07CB0. I have put in a cap kit as well as a new flyback (because the other one exploded). Now the monitor is running but there is an inch and a half or so of the right side of the screen that is smeared or mirrored of the line of pixels just left of it. Also, the H Pos selector doesn't seem to do anything.
Any comments are appreciated.
« Last Edit: March 11, 2008, 01:53:23 am by ncflagg »
Ken Layton
  • Guru
  • Technician
Re: Electrohome G07-CB0 Mirroring
« Reply #1 on: March 11, 2008, 01:39:24 am »
Where did you get the capkit? You did read the notice that cap position C302 has the polarity marked wrong on the foil (solder) side of the board?
There's a couple of non polar caps near C302 that are not normally included in most kits. Were those replaced?
ncflagg
« Reply #2 on: March 11, 2008, 01:51:38 am »
I got the kit from Zanen Electronics. Yes, I got the C302 in correctly. There were some non-polar caps in the kit that I installed. After I put the flyback in (and before I put in the cap kit) it was doing pretty much the same thing. There was also a little warping going on in the left side of the screen but the cap kit seemed to fix that.
ncflagg
Re: Electrohome G07-CB0 Smearing
« Reply #3 on: June 06, 2008, 07:38:17 pm »
I decided to call Zanen electronics today. He said he couldn't envision why a monitor would smear/mirror like that. He suggested I try another game board in it to see if it did the same thing. I hooked it up in another cab with my xbox converter and it looked great! I put a different G07-CB0 in the Speed Buggy and it smears just like the other one. I need to pull out the Speed Buggy board and clean it up/re-seat the chips to try and clear up the smearing.
