Author Topic: WG 25K7401 monitor extreme brightness intermittent problem  (Read 1496 times)
Zanox
  • Last login:November 20, 2011, 12:25:24 pm
« on: March 10, 2008, 07:14:33 pm »
I am having a problem with an arcade machine that I just bought. I have tried it with 3 different sets of game boards so I know its not a PCB problem. The colors and everything are decent enough, but sometimes the thing becomes super bright and you can hardly see anything on the screen. It seems to happen when I lift or close the control panel alot and when im playing zangief in marvel vs capcom and trying to do final atomic busters and I make the cabinet shake a little. Im guessing something is just loose or there is a bad wire. I know its not the best way to fix it, but if I smack the right side of the cabinet it goes back to normal.
Any ideas?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: WG 25K7401 monitor extreme brightness intermittent problem
« Reply #1 on: March 10, 2008, 09:11:42 pm »
good lighting and magnification (if needed ) for a cold solder joint hunt  .....resolder as needed
qrz
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #2 on: March 11, 2008, 11:06:05 am »
or maybe layoff the final atomic busters  :laugh2:
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 11, 2008, 11:19:42 am »
Sounds like bad solder joints most likely.
Zanox
« Reply #4 on: March 12, 2008, 10:00:38 pm »
Thanks for the replies, I will take a look at that this weekend.
