Author Topic: Ice Trackball and LED Wiz  (Read 1077 times)
bent98
  • Last login:February 02, 2019, 03:35:00 pm
  • Hyperspin Moderator
« on: March 08, 2008, 04:37:02 pm »
Anyone tell me how to hook up Ice trackball with led wiz. There is a ribbon cable that has 4 wires one for R one for G one for B and one 5v.
I hooked up Red to a port on LED WIZ and tried to configure in LEDBLinky no dice. Do I need to hok up 5v? I mean doesnt the trackball get the 5V from LED WIZ Board?
robC
  • Last login:December 13, 2017, 11:59:59 am
Re: Ice Trackball and LED Wiz
« Reply #1 on: March 08, 2008, 05:03:49 pm »
Yes, you need to hook the 5V part of the ribbon cable to the 5V output on the LEDWiz, then you would nornally use 3 ports on the LEDWiz for each of the R,G, and B leads of the ribbon cable. Just to test, you can use the control panel app from GGG.
Hope this helps,
Rob
bent98
« Reply #2 on: March 08, 2008, 06:38:34 pm »
Kinda dumb its a stranded wire and not a solid core. Can you put R G B all in same port for LEDWIZ?
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #3 on: March 08, 2008, 06:41:20 pm »
yup...but then you would only get white for your colour...
