Author Topic: WG 25k7193 Information  (Read 4594 times)
Xb0x3r
  • Last login:August 06, 2010, 07:47:33 pm
« on: March 08, 2008, 04:01:08 pm »
Hello, I am the recent owner of two Wells Gardner 25k7193's
I was just wondering what the pinout is on the circuit board so I can hook up my signal wires to it.
Also, it does have an isolation transformer, I know how to power it, but is there anything else on the circuit board I need to externally power?
Thanks,
Xb0x3r
Ken Layton
  • Guru
  • Technician
Re: WG 25k7193 Information
« Reply #1 on: March 08, 2008, 06:49:44 pm »
http://jstookey.com/arcade/WG_25k7191/
If yours has a remote adjustment board, be sure it is connected before powering up the monitor. Make sure the isolation transformer is good and is connected properly before powering up also.
Xb0x3r
« Reply #2 on: March 08, 2008, 07:49:42 pm »
The link doesn't seem to be working  :(
Ken Layton
  • Guru
  • Technician
« Reply #3 on: March 08, 2008, 07:53:53 pm »
Strange, I was just there earlier today and it was fine.
Xb0x3r
« Reply #4 on: March 08, 2008, 08:41:18 pm »
Oh, it's working now thanks for the link  :D
Xb0x3r
« Reply #5 on: March 10, 2008, 09:39:41 am »
Ok so now I've got my monitor powered and connected through a hacked VGA cable, Now I'm wondering how do I get something to display on it? I've tried soft 15khz using "install 15khz" and quickres to get my resolution down to 640x480, but nothing will display :(
Any ideas?
Xb0x3r
« Reply #6 on: March 10, 2008, 09:16:47 pm »
BUMP  ::)
pincky
  • Last login:February 10, 2014, 02:22:07 pm
« Reply #7 on: March 11, 2008, 02:04:28 am »
does it flicker?
Xb0x3r
« Reply #8 on: March 11, 2008, 07:24:50 am »
No not at all...at one point I got it to show some faint lines across the screen but that's it...
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #9 on: March 11, 2008, 09:19:59 am »
I may be missing this assumption but is the monitor actually on?
Is there a faint orange glow in the neck tube?
How are you connecting the "hacked VGA" cable?
Right off the top of my head I don't remember if this chassis is composite SYNC or whatever you call it.  Ken or some of the other guys would probably know.
Also may want to take a look in the "Soft 15KHZ" topic.
http://forum.arcadecontrols.com/index.php?topic=66402.0
Just to confirm that your graphics card is one of the ones that can be used in the first place.  Would be frustrating if it turns out you are just using the wrong graphics card or something.   :cheers:
« Last Edit: March 11, 2008, 09:21:34 am by Lutus »
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Xb0x3r
« Reply #10 on: March 11, 2008, 09:56:37 am »
I am powering the isolation transformer which seems to the the only thing I can power. Also do I need V-SYNC and H-SYNC connected at the same time? Right now I only have V-SYNC connected.
EDIT: For the Hacked VGA Cable I just used an ohm meter to identify the pins and then used the chart from http://www.mrsalty.net/arcade/monitor/monitor.shtml to help me decide which wires I need and then i just taped off the ones I don't need.
Thanks,
Xb0x3r
« Last Edit: March 11, 2008, 10:08:22 am by Xb0x3r »
Ken Layton
  • Guru
  • Technician
« Reply #11 on: March 11, 2008, 11:07:57 am »
You probably need BOTH syncs hooked up. It'll likely be either both NEGATIVE horizontal & NEGATIVE vertical or both POSITIVE horizontal and Positive Vertical.
Xb0x3r
« Reply #12 on: March 12, 2008, 05:13:54 pm »
Nope, still didn't work :(
Any other ideas?
Xb0x3r
« Reply #13 on: March 13, 2008, 07:26:10 pm »
Ok I've got a question, should my normal computer be hooked up to the VGA port on my video card and the arcade monitor on the DVI port (with a converter) or vice-versa?
Also does Soft15KHz work with both ports?
Xb0x3r
« Reply #14 on: March 14, 2008, 10:39:18 am »
Bump ::)
Xb0x3r
« Reply #15 on: March 15, 2008, 01:24:14 pm »
Oh, nevermind, it doesn't use both ports. But I still don't have any picture on the arcade monitor.
