Author Topic: Can you identify this part on the Sanyo 20EZ?  (Read 1620 times)
cornishHen
  • Last login:February 08, 2016, 08:32:23 pm
« on: March 07, 2008, 11:35:26 pm »
I was just tidying up a cinelabs flyback install when this large white part sheered.  I was gently wiping the dust from the top of it.  Any idea what this is?  A resistor?
SirPeale
  • Green Mountain Man
Re: Can you identify this part on the Sanyo 20EZ?
« Reply #1 on: March 08, 2008, 05:38:36 am »
Yes, a resistor.
cornishHen
« Reply #2 on: March 08, 2008, 01:17:52 pm »
After alittle research I think this is 180Ohm 20watt Wire wound resistor..
cornishHen
« Reply #3 on: March 08, 2008, 01:29:00 pm »
is it ok to substitute a higher wattage wirewound resisistor?   Ex.  I have a 180ohm 20W resistor and i was hoping to substitute it with a 180ohm 25 watt?
Kevin Mullins
    • Me on Myspace
« Reply #4 on: March 08, 2008, 02:48:17 pm »
Yes..... just as long as the ohm is correct.
The wattage is how much current the resistor can handle.
And make sure that it stands off from the pcb the same way due to heat buidup.
