Author Topic: Imperial trackball question  (Read 961 times)
tman2k
  • Last login:September 08, 2003, 11:54:41 pm
« on: May 22, 2003, 07:22:33 am »
Hello,
I have an Imperial trackball (arcade one with molex connector) and am designing my control panel.  I don't have an interface for it yet, and am wondering which side is up (with reference to the cable coming out of it...ie, does the cable go up, down, left, right, upper right, etc....)?
zaphod
  • Last login:September 04, 2012, 11:11:38 am
    • ArcadeCab.com
Re:Imperial trackball question
« Reply #1 on: May 22, 2003, 07:35:14 am »
The PS/2 version has it's wires coming out at the lower right, so I assume the other Imperials are the same.
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #2 on: May 22, 2003, 08:25:33 am »
Yes, lower right is the standard.  Wico, betson/imperial, happs, suzo all go out the lower right "corner".
(*Except for a very short run of happs quite a while ago.)
Robin
Knowledge is Power
tman2k
« Reply #3 on: May 22, 2003, 08:58:08 am »
Thank you very much....that helps out quite a bit!
