Author Topic: led-wiz plus led-wiz+gp?  (Read 1438 times)
ivwshane
    • My first mame cab! (WIP)
« on: March 06, 2008, 01:32:34 am »
Is it possible, and by possible I mean relatively easy to use with various light controlling software, to use both an led-wiz plus and a led-wiz+gp?
I plan on using lighted rgb led buttons, but with 7 buttons per player I would max out the standard 32 port led-wiz so I would need at least a 16 port led-wiz and since I also need something to control a few extra buttons I was looking at the led-wiz+gp to take care of both requirements.
Is there any limitations to this setup? If there isn't how would I order this? Do I order a standard led-wiz (device id 1) and then order the led-wiz+gp (device id 2)?
RandyT
  • Last login:July 15, 2025, 12:40:35 pm
    • GroovyGameGear.com
Re: led-wiz plus led-wiz+gp?
« Reply #1 on: March 06, 2008, 02:32:03 am »
In order to maintain compatibility with existing software, both devices use the same USB ID's.  Therefore, to use both on the same system, you'll want to get LED-Wiz  Dev#1 and LED-Wiz+GP Dev#2.
RandyT
ivwshane
« Reply #2 on: March 06, 2008, 02:52:04 am »
Thanks.
That makes things much easier and a little cheaper for me:D
