Author Topic: Wiki Errors - 'Bartop' & 'Other' Project pages  (Read 9458 times)
mr.Curmudgeon
  • It's going to hurt your brain. A lot.
  • Last login:October 11, 2021, 07:15:49 pm
  • Huzzah!
« on: March 03, 2008, 03:11:53 pm »
Can't seem to edit either of these pages. (was going to update with thumbnails)
http://wiki.arcadecontrols.com/wiki/Bartop/Countertop
http://wiki.arcadecontrols.com/wiki/Other_arcade_projects
It says someone else is editing the page, then it rejects the edits, even though no one else is listed. (Stored version only)
Error: "Someone else has changed this page since you started editing it."
On a side note, these are also the only two pages in the "Examples" section that show this error (at the top of the page)
Notice: Undefined offset: -1 in /www/html/wiki.arcadecontrols.com/w/languages/Language.php on line 2329
 :dunno
Cakemeister
  • Last login:May 31, 2024, 06:23:16 pm
Re: Wiki Errors - 'Bartop' & 'Other' Project pages
« Reply #1 on: March 04, 2008, 09:28:46 pm »
I wanted to edit that, too, to move the bartop/countertops out of the "other" section to the "bartop/countertop" section, and I got the same error.
Maybe Space Fractal would know what the problem is.
Old, but not obsolete.
mr.Curmudgeon
  • Huzzah!
« Reply #2 on: March 04, 2008, 09:35:52 pm »
Yeah. Aren't there a lot of doubles there?
Cakemeister
« Reply #3 on: March 05, 2008, 08:13:56 am »
I actually copied them over but I haven't taken them out of the "other" section yet. So they are currently duplicated until I go through them and sort them out into which ones belong in "other" and which ones belong in "bartop/countertop".
sirwoogie
  • Supreme Chancellor
  • Last login:April 23, 2025, 10:29:35 pm
  • It's Hollyfeld in a Winnebago!
« Reply #4 on: March 14, 2008, 01:15:14 pm »
The wiki needs some TLC. Are you guys still getting the edit issue?
Cakemeister
« Reply #5 on: March 14, 2008, 07:12:59 pm »
Yes, under the Bartop/Countertop section of the examples.
MazzMn
  • Last login:March 19, 2013, 12:38:19 am
  • chicken, fight like a robot
    • The IceBox Oak Cocktail Table
« Reply #6 on: March 28, 2008, 12:08:07 am »
I tried to create a copy of the page and rename (by moving) the original page...In the process I believe the page is now working again, see if it works for you all
Cakemeister
« Reply #7 on: March 28, 2008, 11:43:22 am »
That works for me. The "other proiects" needs to be moved to the end of that line of links and the bartop/countertop projects need to be cleaned out of there.
MazzMn
« Reply #8 on: March 28, 2008, 06:53:53 pm »
All the pages the same header that can be used to navigate between categories.
I decided there should be both an Other and Bartop/Counter top category and so cleaned up the dupes.
