Author Topic: Cocktail mode in Mala  (Read 4124 times)
astro57
  • Last login:May 27, 2008, 11:27:25 pm
« on: March 02, 2008, 06:03:03 pm »
I can't seem to get the screen to flip when going from player one to player two. I'm also pretty new to this.  I've built a cocktail cabinet and I have been trying mala as a frontend.
Thanks, Dave
loadman
  • Moderator
    • MaLa
Re: Cocktail mode in Mala
« Reply #1 on: March 02, 2008, 09:12:44 pm »
Thanks, Dave
Flip the MaLa menu or Flip when playing a Mame game?
astro57
« Reply #2 on: March 02, 2008, 10:28:57 pm »
Flip when playing the game, player two is on the same end as player one. The game is set to cocktail cabinet in the dip settings.
lcddream
  • Last login:December 04, 2024, 03:59:31 pm
  • Say goodbye to gravity...
« Reply #3 on: March 02, 2008, 10:56:39 pm »
Which game is it?
Did you try reseting the game after changing the dip switch setting to cocktail?
Also just an FYI, having the game flip back and forth between player one and two in cocktail mode is controlled by mame not MaLa.
astro57
« Reply #4 on: March 02, 2008, 11:15:22 pm »
I tried chopper lifter and ms pac man, do all games flip? Is there something in mame I should be changing? Thanks
lcddream
« Reply #5 on: March 02, 2008, 11:27:45 pm »
No not all games have cocktail mode. Not sure about choplifter, but Ms Pac does.
If you press tab while in the game, a menu will come up.
Select Dip Switches.
If there is a cab type option, change it from upright to cocktail.
Escape back to first menu and select reset game.
When you start a two player game it should flip back and forth in between players in cocktail arcade fashion.
I have seen games that have the cocktail dipswitch but still don't flip.(They also didn't have the mame disclaimer of cocktail mode is not supported.)
