Author Topic: Arcade Monitor Problem  (Read 2742 times)
tman2k
  • Last login:September 08, 2003, 11:54:41 pm
« on: May 21, 2003, 07:17:07 am »
Hello,
I have a dark area at the bottom of my arcade monitor (see the circled part in the picture below).  What is this?  Is this monitor burn-in?  Or would a cap kit fix it?
Disregard the display on the monitor...the game itself is totally screwed up and not working, and is in pretty rough shape...a good candidate for a mame conversion!
paigeoliver
  • Awesome face!
Re:Arcade Monitor Problem
« Reply #1 on: May 21, 2003, 07:30:26 am »
I don't see a picture. But in general always try a cap kit first to fix anything that won't adjust away with the little adjustment knobs.
tman2k
« Reply #2 on: May 21, 2003, 08:49:14 am »
Hmmm, I know I added a picture...not sure why it is not there...does it have to be approved by a moderator first?
tom61
  • Last login:September 18, 2017, 12:46:56 am
« Reply #3 on: May 21, 2003, 04:29:59 pm »
Nope. It should just post.
tman2k
« Reply #4 on: May 22, 2003, 01:18:21 am »
OK, then let's try this again....I am hitting the browse button and selecting my jpg...
tman2k
« Reply #5 on: May 22, 2003, 01:19:35 am »
There we go...it worked this time, and I didn't do anything different....oh well, blame it on Gremlins!
Anyway, is this burn in or something else?
paigeoliver
  • Awesome face!
« Reply #6 on: May 22, 2003, 05:16:23 am »
Burn in manifests itself as a ghost image that you can see all the time.  That looks like something else. I would cap the thing first and if that doesn't fix it then I would go looking for a new tube (that could be a cap problem or a tube problem).
AlanS17
    • AlanS17
« Reply #7 on: May 23, 2003, 01:36:00 pm »
I'm not too sure a cap kit will fix that, and it doesn't look like traditional burn-in either.
To me it looks like a one of a couple of (unfixable) problems.
1) It may have been left too close to a large magnet or large power source. This would create a sort of "super-burn in" where all the electrons get pulled down into the corner and basically torch it.
2) The inside of the screen itself may be pealing up or flaking off.
I'm tempted to say it's the latter of the two judging by the shape of the mark. I notice it has a curve. Are the edges or the mark pretty well defined? (Picture a literal hole in the image.)
That's my best guess by looking at it. Of course, I am by no means an expert so don't take everything I say as gospel...
loksenna
  • Last login:July 14, 2003, 09:58:52 pm
« Reply #8 on: July 08, 2003, 12:07:41 am »
I have some similar black marks on my DD3 monitor.  My stuff was on the outside of the monitor and was due to it slowly burning the cardboard divider.  I just took a paint scraper (thin razor kind) and scraped it off.  I hope this helps.
Hmm... I wonder what happens when I touch this to tha
Ken Layton
  • Guru
  • Technician
« Reply #9 on: October 26, 2003, 01:54:08 am »
If the picture tube hasn't had any rough handling then you should start with a cap kit.
