Author Topic: This is possible? S-VIDEO TO RGB SCART.  (Read 2193 times)
cleric
  • Last login:June 07, 2003, 05:39:19 pm
« on: May 20, 2003, 11:35:54 pm »
Hi
I have a Ati Rage Fury 32mb VIVO, but my Grundig TV dont have S-video input only RGB SCART.
I dont want to use component video output, because the picture is not good.
So i asking if is possible to convert the S-video signal from the ati card to  RGB Signal for the TV RGB SCART input??
Thanks 8)
Dave_K.
  • Last login:July 06, 2022, 03:27:30 pm
    • Arcade Fever
Re:This is possible? S-VIDEO TO RGB SCART.
« Reply #1 on: May 21, 2003, 03:15:32 am »
Hi
Thanks 8)
Ok just for clarification, what you ment to say was COMPOSITE video output is not as good as s-video.  Component video is a much higher quality than s-video.
Second: European SCART inputs take s-video. As seen here http://www.gamesx.com/hwb/co_Scart.html pins 15 and 20 are Chomanince and Lumanance, use pins 13 and 17 for grounds....and you have all 4 connections which make up an s-video connector.  So all you have to do is hack a SCART cable to an s-video cable using these pins.
Here is a diagram of the pins for s-video http://www.pccables.com/70714.htm
« Last Edit: May 21, 2003, 03:17:12 am by Dave_K. »
cleric
« Reply #2 on: May 21, 2003, 08:41:36 am »
OK. But this is only a way to hack the s-video cable to scart.
I am talking about real RGB signal from S-video,  RED GREEN BLUE.
There is any way ??
I found this for Composite Video  PAL -> RGB
Dave_K.
    • Arcade Fever
« Reply #3 on: May 25, 2003, 02:59:17 pm »
There is any way ??
I don't think you understand what you are asking for.  There is no RGB in s-video.  Yes, there are converter circuits which try to build a fake RGB signal from s-video but what you will get is poor RGB signal (worse than the s-video).  Converting composite or s-video to RGB is not what you want.  You'd be better off hacking the svideo cable to your scart conntor like I mentioned.
