Author Topic: does the arcadevga runs the latest MAME?  (Read 3322 times)
Denverlatino
  • ---Buyer Beware - transactions with this user are in dispute--- ... Banned ...
  • Last login:May 13, 2009, 02:55:24 pm
« on: February 22, 2008, 08:20:37 pm »
This may be more a hardware than software question but i want to build another cab for my room and i was wondering if the arcadevga card runs the latest MAME with no problems, Thanks for reading and for your help.
[transactions in dispute -- see http://forum.arcadecontrols.com/index.php?topic=77030.0]
... Banned ...
ahofle
    • Arcade Ambience Project
Re: does the arcadevga runs the latest MAME?
« Reply #1 on: February 22, 2008, 10:29:49 pm »
Yes (I'm using he AVGA2, AGP version)
Denverlatino
« Reply #2 on: February 23, 2008, 09:09:44 pm »
thank you
... Banned ...
« Reply #3 on: February 24, 2008, 09:02:18 pm »
I am using version .119 of MAME with the Arcade VGA2 PCIe version.
« Reply #4 on: February 26, 2008, 10:40:56 am »
What video settings are people using for this?  I've had a guess at it, not tried it out on the AVGA yet tho...
ahofle
« Reply #5 on: February 26, 2008, 11:16:14 am »
In general, video=ddraw, nohstretch, switchres.  And then pick the resolution closest to the game's resolution.
« Reply #6 on: February 26, 2008, 11:55:49 am »
Thank you.  I recall when v0.107 came out there was some problem with using d3d which is probably why you say use ddraw.  Can you remind me what is the problem with d3d?
ahofle
« Reply #7 on: February 26, 2008, 12:12:31 pm »
D3D always seems to 'scale' the game to the screen resolution resulting in some blurring.  This is actually good when running a high resolution LCD or CRT (takes the edginess out of the game), but sucks when you are trying to run an arcade monitor at the same low resolution as the game.  With ddraw and no hardware stretch, MAME will not scale anything and you will get a pixel perfect image.
« Reply #8 on: February 26, 2008, 01:47:05 pm »
Ah ok...presumably not such an issue if you have a video mode available to exactly match the games mode, but this is often not the case.
Thanks again!
ahofle
« Reply #9 on: February 26, 2008, 02:55:40 pm »
I actually have yet to find a D3D resolution setting that doesn't show the scaling/blurring.  I still don't understand why that is.  :dunno
« Reply #10 on: February 26, 2008, 03:05:52 pm »
You should take a peek at the AVGA installation page found here:
http://www.ultimarc.com/avgainst.html
In it is a section that outlines the changes that Ahofle mentioned for MAME:
# VIDEO OPTIONS
video ddraw
numscreens 1
window 0
maximize 1
keepaspect 1
prescale 1
effect none
pause_brightness 0.65
waitvsync 0
syncrefresh 0
# DIRECTDRAW-SPECIFIC OPTIONS
hwstretch 0
# FULL SCREEN OPTIONS
triplebuffer 0
switchres 1
Hope this helps!
~ DeLuSioNaL
northerngames
  • Trade Count: (+18)
« Reply #11 on: February 26, 2008, 07:21:30 pm »
also the AVRES tool automaticly sorts and checks to display the correct screen res for that particular game choosen instead of doing them one by one manually setting the res's for each.
« Reply #12 on: February 27, 2008, 04:37:44 am »
I see what you mean. I tried it, at 256x240 which is the correct resolution for the game I ran (Buggy Boy), and it looked very odd, like it was using a resolution even smaller and squashing the image to fit on thus missing bits out.
Works great with ddraw tho  :)
MAME TIME
  • Last login:March 23, 2019, 10:23:19 pm
« Reply #13 on: February 27, 2008, 12:59:53 pm »
Triple buffer works better with older versions ie 106, 110. any higher i get sound stutter in games, Mind you i have a beefy system
Too Much Game, check out my ish!!!
Geometry Arcade
Neo Geo 360
MK2 standup
SF2 champ edition X2
Jdurg
« Reply #14 on: February 27, 2008, 01:15:03 pm »
That's because the newer versions of MAME have tied the emulation into the video aspect of the game so if your display has a refresh rate lower than the refresh rate of the game, it won't matter how beefy your system is the games will stutter.  So to correct this, you just need to make sure that your screen's refresh rate is equal to or higher than the refresh rate of the game.  (E.G. if the game runs at 60.1 Hz, you will need to have your screen's refreshrate at 60.1 Hz or higher in order to avoid sound stuttering).
Why was this change made?  Because it is far more accurate to how the arcade games ran.
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
« Reply #15 on: February 27, 2008, 01:41:03 pm »
I am not disagreeing, but I *always* found this to be the case with MAME.  Especially when I first started using the AVGA card.
Yes I agree.  I improved my 'MAME Resolution Tool' to allow exactly this some years ago.
