Author Topic: caster wheel rating.  (Read 1218 times)
SavannahLion
« on: February 22, 2008, 06:23:54 pm »
I always forget. When calculating caster wheel weight ratings, is the rating for each caster or for a set of four?
For instance, if a single caster is rated for 200lbs, then using four casters means that the total rated weight load is 800lbs?
Some of these casters seems really light duty to be bearing a 200lb load without busting a weld or grinding out the bearings.
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
Re: caster wheel rating.
« Reply #1 on: February 24, 2008, 08:20:39 pm »
If I remember my hardware correctly the rating is the amount each loaded wheel can carry safely.
So a 100 lb capacity wheel on each corner of a evenly distributed load SHOULD hold 400 lbs. The problem comes with an uneven load like a arcade cabinet ie. the monitor is front heavy.
My advice is to use a wheel or caster that can carry about 20 percent more than the total weight of the loaded cabinet.
Hope that helps.
There are three kinds of people in the world those that can count and those that can't.
bfauska
« Reply #2 on: February 25, 2008, 12:07:44 am »
That's how I've always read the ratings, and I build things with 20 casters holding 1500lbs. The reason I use that example is to point out that a rating system based on using 4 casters would only apply sometimes in the grand scheme of things, an individual rating is much more useful overall.
Assuming an even load 4 casters rated for 100lbs ea. should carry 400lbs.
SavannahLion
« Reply #3 on: February 25, 2008, 02:33:02 am »
Thanks for the answers. That's what I figured.
It's hard to tell with these casters and how some of them are marked... or not marked.
