Author Topic: Happs Joystick question (which to buy)...  (Read 3163 times)
cLaM729
« on: March 16, 2002, 01:58:14 am »
hey all.
i am adding a 4way only joystick to my cab (i already have two 8 ways). which is the best joystick from happs ? the "ultimate", "super" or "universal" ?
thanks.
Tiger-Heli
    • Tiger-Heli
Re: Happs Joystick question (which to buy)...
« Reply #1 on: March 16, 2002, 07:26:09 am »
http://www.happcontrols.com/joysticks/5060841125r.htm
This one, it's a replacement for the Ms. Pac-Man/Galaga reunion games and therefore a true 4-way.  $21.00 though  :-[
J_K_M_A_N
« Reply #2 on: March 16, 2002, 09:32:50 am »
cLaM729
« Reply #3 on: March 16, 2002, 01:23:13 pm »
thanks for the info.
two questions, 1) is the red knob replaceable with a black one (sounds silly, but i like things to match =) ?
and 2) i would mounting this in the front of my hotrodse, why is this joy only metal mountable ? couldn't tell from the diagrams on the site.
thanks all.
Trenchbroom
  • Last login:November 21, 2020, 09:25:43 pm
  • Wampus? Get over here!
« Reply #4 on: March 16, 2002, 01:39:14 pm »
thanks all.
It's not wood mountable because of the short shaft and throw of the stick.  You really need a very thin mounting material for it to work properly.  I recently purchased one and it is a very small joystick.
Has anyone mounted one of these in a lexan surface?  Thought it would be easier to drill a lexan plate than a metal one.
Red ball?  I'm not sure if it twists off or not.    Will have to go look.
ddebuss
  • Last login:January 20, 2015, 07:48:10 am
  • Stuck in the 80's
« Reply #5 on: March 16, 2002, 02:24:53 pm »
The ball is not removable.  It can be painted with the proper paint and preparation.
