Author Topic: Will a 27" monitor fit this cabinet?  (Read 2195 times)
Ummon
  • Trade Count: (+13)
« on: February 20, 2008, 05:23:49 pm »
I really like this design for a Mame cabinet. It seems these normally come with 25" monitor. Does anyone know if a 27" monitor will fit in one?
Yo. Chocolate.
Stephen Hawking
IG-88
Re: Will a 27" monitor fit this cabinet?
« Reply #1 on: February 20, 2008, 06:15:49 pm »
I take it you aren't in a position to measure it?
-HarumaN
Ummon
« Reply #2 on: February 21, 2008, 03:17:03 pm »
I'm looking for one, if it will fit a 27" monitor.
Yo. Chocolate.
Stephen Hawking
enchntr
  • Last login:January 23, 2013, 07:49:56 pm
  • All Around Star Wars Nut
    • Power of the Force.com
« Reply #3 on: February 22, 2008, 03:51:01 pm »
Same cabinet:
Yes, a 27 inch fits okay.  You will need to notch the monitor tray to accept the bottom ears, find a way to keep the monitor upright (I have a large dowel going across the top ears of the monitor) and remove the 27" rear brackets.  It's tight, especially with the neckboard being almost against the back door.
Personally, I'd keep the 25"er as the 27" is somewhat tough to play on.  I'm actually looking to sell mine due to a move, and would go back to a 25"er in a heartbeat.  Sometimes, bigger is not necessarily better.
« Last Edit: February 22, 2008, 03:54:59 pm by enchntr »
Ummon
« Reply #4 on: February 23, 2008, 06:45:38 pm »
Thank you. Where did you come across yours?
Yo. Chocolate.
Stephen Hawking
enchntr
« Reply #5 on: February 24, 2008, 09:45:55 am »
Local guy selling a world class bowling deluxe.  It needed some TLC.
JoeB
  • Last login:January 28, 2026, 10:28:49 pm
  • NES Fanatic
« Reply #6 on: February 25, 2008, 12:21:13 am »
Hey Enchntr,  thanks for sharing!
Any way you can share pictures of how you have it mounted in the side the cab?  What you needed to do to make it fit, etc?  Also, where you did find the 27" bezel.
The reason a lot of people might be looking for a way to fit a 27" is because that's a very common arcade machine from the 90's which can be found empty for less than 100$.. but good luck finding a 25" monitor.  Only 27" TV's are currently available in the market.
