Author Topic: Running older versions of MAME  (Read 4727 times)
Steven633
  • Last login:September 01, 2008, 03:44:19 pm
« on: February 17, 2008, 06:48:43 am »
NEWB ALERT....
I have tried downloading an older version of MAME to run on a low spec machine but can't get it to work. I have tried MAME055b.zip, unzipped it then clicked on the MAME exe but all I get is the command line window which flashes up for a second with a error message I can't read in the short time it appears for, then nothing.
Is there anything else I need to download to make this work. My newer versions of MAME run fine on my machine. :dunno
gonzo90017
Re: Running older versions of MAME
« Reply #1 on: February 17, 2008, 12:34:47 pm »
That's because it's the command line version. Download SendtoToys http://www.vnunet.com/vnunet/downloads/2174614/sendtotoys and when installing it make sure to only enable command prompt. Then you can right click on mame.exe and select command prompt and type the full path to your rom inclucin extension and it should launch your game. The advantage of this method is that it uses less resources. It's better to use it with a frontend.
Or you can download the Mame32 version. http://www.joymonkey.com/main/index.php?n=MAME32Archives.053To059  :laugh:
« Last Edit: February 17, 2008, 05:56:55 pm by gonzo90017 »
SGT
  • Last login:May 31, 2025, 10:10:32 pm
« Reply #2 on: February 17, 2008, 05:26:28 pm »
Steven633,
Steven,
Go to the C prompt:
Code: [Select]
Start -> Run -> CMD <enter>Change to the folder where your mame is located, for example:
Code: [Select]
CD \emulators\mame <enter>Start  Mame with a rom name, for example:
Code: [Select]
Mame pacman
The game will either start up or will give an error such as the rom has missing files which means your rom version is not for the version of Mame that you have.
As gonzo already pointed out, this command line version of Mame works well with a front end, or try the mame32 version which has a front end built in with a gui.
ArtsNFartsNCrafts
  • Last login:October 12, 2020, 09:22:50 pm
« Reply #3 on: February 19, 2008, 06:14:25 pm »
do any front ends work in cunjunction with Mame32?  I know that Mame32 is basically its own UI, but I'd prefer to make it looks less "windows'y", and The romset for mame32 is the only one that works perfectly on my system.
SGT
« Reply #4 on: February 19, 2008, 06:18:06 pm »
Some will work though its not recommended to use a frontend to run a frontend.  If mame32 works with your romset, so will the the command line version.   You can download old versions of mame command line just like you can for mame32.  What version is your romset?
ArtsNFartsNCrafts
« Reply #5 on: February 21, 2008, 07:34:30 pm »
Not even sure, man.  I "picked and chose," as I didn't want a thousand roms I would never play on my machine.   :-\
SGT
« Reply #6 on: February 21, 2008, 07:43:31 pm »
What version of mame32 are you using?  The same version of command line mame will work with your roms.
protokatie
« Reply #7 on: February 21, 2008, 08:31:34 pm »
Although it is prolly smarter to use the command line version with MALA/etc, I havent had any problems using MALA with MAME32. I just did a test to make sure: When I run MALA, it doesnt even start up the MAME32 front end, so I presuming that MALA (and prolly a lot of other FEs) treat MAME32 just as a command line program.
SGT
« Reply #8 on: February 21, 2008, 09:35:33 pm »
Once you go command line, you'll never go back.  >:D
TelcoLou
  • Four score and seven years ago our fathers brought forth on this continent, a new nation
  • Last login:October 14, 2010, 01:28:19 am
  • Playing video games since 1977
« Reply #9 on: February 21, 2008, 11:02:50 pm »
So true. I was using MAME32 for the longest time, then switched to the command line version to use w/MAMEwah.
I noticed a difference in default screen resolutions too; the command line version seems more consistent, in regards to centering the game to the monitor.
« Last Edit: February 21, 2008, 11:06:35 pm by TelcoLou »
So a leper walks into a bar and as he gets his beer, a finger falls off. The bartender who is serving him turns and pukes all over the place. The leper, feeling bad, says, "Was it my finger falling off?" The bartender turns to him and says, "No, it's the guy dipping chips into your back."
protokatie
« Reply #10 on: February 22, 2008, 12:37:26 am »
Odd, i have never had any problem with that "sort of thing" with MAME32... Maybe it is the hardware I am using, or the settings I gave to MAME32... Then again, I am using MALA, and it may treat MAME differently... (BTW, I did change some of the MAME32 default settings, such as to "not change resolution" and some other stuff, so that may account for my different experience...)
ark_ader
  • I glow in the dark.
« Reply #11 on: February 22, 2008, 10:50:03 pm »
I mean what are we talking about here?
P3? P2? 486? Low spec?  How about a 386?
Just run it with Mame .36 and ArcadeOS.
If I can get Pacman to run on a 486/25 in 8mb on a CF.  There shouldn't be an issue.
We need to know what spec and then we can help on the version and what you need to get you on the right path.
Gee guys, you need to read the opening post before jumping in.... :banghead:
SGT
« Reply #12 on: February 23, 2008, 12:21:07 am »
The first post has this:
I'm having a hard time understanding how your post addresses this.  If he can't get .055 working, what makes you think .036 is going to be better?
BASS!
  • Just have fun.
« Reply #13 on: February 23, 2008, 12:49:01 am »
I like using mamefx mameXT and mamepp in conjunction with either maximus arcade or mala.
http://www.mamext.net/
http://mame-emu.blogspot.com/
http://mame32fx.altervista.org/home.htm
http://mala.arcadezentrum.com/
http://maximusarcade.com/
mala and max both work with even the most current versions of mame
ark_ader
« Reply #14 on: February 23, 2008, 04:15:15 am »
What? Are you serious ? :dizzy:
Maybe he is using an earlier romset?   ::)
SGT
« Reply #15 on: February 23, 2008, 08:37:09 am »
Please wake up.  You asked why we posted what we did.  We posted for him to run from the C prompt so that we could get the exact error message.  This was so we could determine if he had the correct romset.  Since he was not running from the C prompt, the error message did not stay on the screen long enough.  Before you criticize other posters, please try to understand what it is being posted.
So to recap, we're trying to determine what the error message says (which would tell us if the error is due to an incorrect rom set).  You posted:
WHICH IS WHAT WE ARE TRYING TO DETERMINE!!!!! :banghead:
Of course your first post in this thread was:
Wow ::)  Let's not find out what the problem is, let's just try different Mame versions until we find one that works. :laugh2:
ark_ader
« Reply #16 on: February 24, 2008, 01:27:59 am »
Well the point in any excercise to help someone who has a problem is to ask probing questions.
I had the same problem with the pacman.rom in several versions of MAME.  Neither of them ran and gave me the issue that our friend has.  In the end it was a faulty rom file, so there still be many other problems we have to explore to find his solution.  It could be something simple or quite puzzling.
Lets not start back and forth banter, lets just try to help him in a positive manner.
