Author Topic: 2005 GOLDEN TEE FORE WIRING HELP  (Read 2469 times)
CEE1281
  • Last login:February 17, 2008, 11:32:32 am
« on: February 16, 2008, 03:31:25 pm »
First off i hope this is the right section to post this ? if not my bad.I have a golden tee 2005 green board and im trying to hook up a new power supply.there is 2 9 pin connectors and 1 three pin connector coming off the power supply.i know where the 3 wire connector goes to but the 2 9 pin connectors im not sure.I know there is a 9 pin connector going from the board to i believe the hard drive and i know one of the 9 pin connector off the power supply hooks up to it but im not sure which of the 2 connectors off the power supply hook up there.i dont want to hook them up backwards and fry something.i appreciate any help.thanks.
sarge
  • Last login:April 27, 2015, 01:42:54 pm
Re: 2005 GOLDEN TEE FORE WIRING HELP
« Reply #1 on: February 16, 2008, 06:18:23 pm »
It really doesn't matter.  They are all wired the same, as long as nobody has altered them.   One 9 pin is used to power the board/hard drive assembly and one is used to power the led sign.  There was also a wiring upgrade made to these boards that powered the board through the 4 pin molex connectors on the board rather than through the edge connector.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 17, 2008, 12:08:28 pm »
Contact tech support at the manufacturer www.itsgames.com
