Author Topic: What is this ac adapter called?  (Read 1985 times)
heemid
  • Last login:December 04, 2015, 01:02:18 pm
« on: February 16, 2008, 11:08:33 am »
What is the real name of this and where can I buy them in the US? Tried all the big box store (HomeDepot/Lowes). I know Ive seen one with screw holes and a power switch. Does Happ carry them?
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: What is this ac adapter called?
« Reply #1 on: February 16, 2008, 11:09:56 am »
I've been looking for attachments like this for exterior shell mounting, but they're not easy to come by.
Ken Layton
  • Guru
  • Technician
« Reply #2 on: February 16, 2008, 11:19:26 am »
Called "AC Power Inlet, Flanged". Usually listed in catalogs under "Power Entry Filters and AC Receptacles".
Jameco Electronics has them (www.jameco.com).
Here's the one you pictured:
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&pa=16652&productId=16652
« Last Edit: February 16, 2008, 11:21:00 am by Ken Layton »
heemid
« Reply #3 on: February 16, 2008, 11:31:41 am »
Thanks for the link, am I crazy or has anyone else seen the ones with a red power switch?
Orclord
  • Last login:October 16, 2009, 03:09:38 pm
« Reply #4 on: February 16, 2008, 11:37:43 am »
« Last Edit: February 16, 2008, 12:50:12 pm by Orclord »
heemid
mountain
  • Trade Count: (+9)
  • Last login:January 29, 2025, 08:31:47 am
    • Mountain Jukeboxes
MaximRecoil
« Reply #7 on: February 16, 2008, 03:17:31 pm »
The part you have pictured is known as a "C14 chassis plug". The type of connector on the end of a power cord that plugs into them is known as a "C13 line socket". These are usually collectively referred to as "IEC connectors".
Franco B
« Reply #8 on: February 16, 2008, 03:39:23 pm »
Mate, Maplins do loads of them.
http://www.maplin.co.uk/search.aspx?MenuNo=13276&FromMenu=y&doy=16m2
Im using one in my I/O panel.
EDIT: Ooops, didnt see Orc had beat me too it.
« Last Edit: February 16, 2008, 03:41:05 pm by Franco B »
Turnarcades
    • Turnarcades
« Reply #9 on: February 16, 2008, 03:47:52 pm »
Cheers!
psychotech
    • psychotech
« Reply #10 on: February 16, 2008, 08:05:50 pm »
So, this is for real?
Well..
I have three (3) of them on my jukebox/pinball only... Cost me about 1 € - 0.33 á - and, come on.. Very easy to come by if you can use a screwdriver ;) When a PSU blows the other components most likely are still usable?
Anyway, there's one in every PC PSU.. Not to mention the male power connectors and fans and all the wiring & molex connectors available (almost) for free :)
A local PC supplier here sells these "nonworking" PSUs for 1€ apiece. So, I bought 6 for 2 Euros ;) ..talk about wholesale..
Come on. Really? Where can I find.....................
