Author Topic: Quick noob question - Billabs Tri-Sync BL19C90T  (Read 2976 times)
nen10dough
  • Last login:April 01, 2012, 03:34:51 pm
« on: February 13, 2008, 07:51:22 pm »
How do I power on this monitor?
My last monitor had a normal 3-prong plug, guess I simply expected this one to be the same.  So I need to buy a power supply, or can I use my computer's?  These are the only cables that came with the monitor along with the VGA cable.  Any helpful links out there someone can recommend?
« Last Edit: February 13, 2008, 08:01:57 pm by nen10dough »
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Quick noob question - Billabs Tri-Sync BL19C90T
« Reply #1 on: February 13, 2008, 10:07:51 pm »
ac line consists of hot , ground and nuetral. u could wire up a 3 prong plug accordingly ......
qrz
nen10dough
« Reply #2 on: February 14, 2008, 10:24:29 am »
thanks q, never had to wire up an actual plug before, but i guess there's a first time for everything!  thank god for the internet.
nen10dough
« Reply #3 on: February 14, 2008, 01:20:54 pm »
So just to confirm, all I would have to do is attach the three wires (hot, ground, neutral) from the molex connector to an appliance cord using wire nuts, plug it into a wall socket and I'm good to go?  Also, this monitor doesn't require an isolation trasformer, so no worries there.
I'm just looking for a quick nod here so I don't have to worry about blowing this baby up, assuming I connect the correct wires together.
« Last Edit: February 14, 2008, 01:22:39 pm by nen10dough »
Ummon
  • Trade Count: (+13)
« Reply #4 on: February 15, 2008, 01:17:21 pm »
It didn't come with a manual that shows a picture or schematice of the wiring harnesses? Also, do a site search. At least one person semi-recently has installed one of these in their cab.
Yo. Chocolate.
Stephen Hawking
nen10dough
« Reply #5 on: February 15, 2008, 02:26:40 pm »
Yeah it didn't come with any instructions, just the two cables.  I wired the molex cable up last night to an AC power cord and it booted fine.  Thanks for the advice.
ahofle
    • Arcade Ambience Project
« Reply #6 on: February 15, 2008, 03:58:26 pm »
Could you post the pinouts in case someone else searches this and has the same issue?
nen10dough
« Reply #7 on: February 26, 2008, 11:27:28 am »
Sorry so late.  I snapped a pic for anyone who might need it.  All I had to do was take the supplied molex cable and cut off one of the connector ends, then wire a standard appliance cord (I got mine for $7 at Home Depot) to the three wires using screw nuts.  There's a molex slot on the monitor where the newly wired cord connects to, and that's pretty much it.  The green is ground, the purple are hot and neutral.  I plugged it in and it powered on fine.
ahofle
« Reply #8 on: February 26, 2008, 12:14:40 pm »
Good deal.
How are you liking the monitor?  Is it working well for CGA, EGA, and VGA games?  How are the controls, etc?
nen10dough
« Reply #9 on: February 29, 2008, 10:26:32 am »
I managed to boot it up once and everything seemed fine, although I didn't get to do as thorough a test as I had wanted.  Unfortunately, I had a computer meltdown with my mame cab and I haven't been able to use the monitor since.  It appears to be the motherboard and it's set me back quite a ways.
