Author Topic: HARDDRIVE LIGHT ON ALL THE TIME  (Read 2351 times)
06attaker
  • Last login:January 11, 2016, 03:39:39 pm
« on: February 13, 2008, 10:33:42 am »
I HAVE A PENTIUM 3 WITH 30 GIG HARDDRIVE AND LITTLE OVER 300 MEG RAM AND HAVE ABOUT 200 GAMES ON IT WITH WINDOWS XP.  EVERYTHING WORKS BUT THE HARDDRIVE LIGHTS STAYS ON ALL THE TIME AND THE FLOPPY DRIVE FLICKERS WHEN LOADING GAMES BUT THERE IS NO DISK IN THERE.  ANY INFO PLEASE?????
THANK YOU!!!!!1
Hoopz
  • Intellivision Rocks!
Re: HARDDRIVE LIGHT ON ALL THE TIME
« Reply #1 on: February 13, 2008, 10:43:32 am »
Sounds serious.  It may be affecting your keyboard also.  Does it make your Caps lock stay on too?
May be something with your hard drive, the lack of ram for running XP and the page file etc.  I wouldn't worry about it too much.  I'd remove the floppy drive altogether if you don't have a need for it.
Edit: Typo
« Last Edit: February 13, 2008, 11:06:47 am by HooPZ »
Dazz
  • Last login:January 11, 2025, 07:43:39 am
  • HyperSpin Team
    • VPUniverse
« Reply #2 on: February 13, 2008, 11:02:59 am »
What is a floppy drive?  I've not seen one of those in years...  I'd worry more about the stuck CAPS LOCK key on the keyboard that is the bigger issue.
Seriously though... this simply sounds like the case LED wires connecting to the motherboard are switched around.  Check your motherboard diagrams and look at the power button/case led/hdd led wires and make sure they are going to the correct terminals on the motherboard.
« Last Edit: February 13, 2008, 11:21:35 am by Dazz »
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« Reply #3 on: February 13, 2008, 03:42:42 pm »
That's what it sounds like to me too...
Encryptor
  • Trade Count: (+34)
« Reply #4 on: February 13, 2008, 04:18:01 pm »
I would agree. It sounds like the led wires are swapped. If that's the case the floppy light will stay on if the floppy data cable is on back words.
Encryptor
TheShanMan
    • My Arcade (updated 1/30/13)
« Reply #5 on: February 13, 2008, 06:24:52 pm »
:laugh2:
