Author Topic: Advice for fixing my mistake?  (Read 1821 times)
specksynder
  • Last login:February 20, 2011, 05:31:31 pm
« on: February 10, 2008, 09:52:58 pm »
You guys did so well on my last question that I have one more: On my completed cabinet, I drilled a 1-1/8" hole for a button on the side of the cabinet (for the coin button).  However, the button wouldn't fit there because the monitor was right behind the hole and there wasn't enough clearance for the button.
So I moved the button down a couple of inches and it works fine.
But I have a 1-1/8" hole in my cabinet.  Does anyone have a nice suggestion for covering that hole?  Is there a cool light or something I can stick there?
arcadefever
  • Miami Beach Florida
Re: Advice for fixing my mistake?
« Reply #1 on: February 10, 2008, 09:57:25 pm »
Buy some wood filler in any hardware store.
let it dry, and paint over  ;)
Sir Auros
  • Last login:December 06, 2012, 12:13:00 pm
    • The Transformers Archive
« Reply #2 on: February 10, 2008, 09:58:34 pm »
For a hole that big? Shouldn't he glue in a wooden plug and then use wood filler?
specksynder
« Reply #3 on: February 10, 2008, 10:01:13 pm »
Yeah, I could patch it a couple of ways no problem... just wondered if there were other creative ideas.
iano
  • Last login:June 15, 2011, 03:39:11 pm
« Reply #4 on: February 10, 2008, 10:03:42 pm »
Hi. You could use a button plug (i think thats what they're called anyway). It's (you guessed it) to cover up an unused button hole (it's plastic and usually colored black). You see them on ebay from time to time.
koolmoecraig
    • My Intervention
« Reply #5 on: February 10, 2008, 10:16:13 pm »
Kind of late but you could have just used a smaller button.
Go buy a wood dowel and cut off the depth that you need. Plug the hole with it and throw some wood filler on it.  Sand and paint or cover with your CPO or whatever.
« Reply #6 on: February 11, 2008, 07:56:37 am »
Put a bottle opener over it.
arcadefever
« Reply #7 on: February 11, 2008, 11:38:10 am »
shardian
« Reply #8 on: February 11, 2008, 11:41:18 am »
If the cabinet is done and you don't feel like filling/painting/sanding etc, just drill a matching hole on the other side and use button plugs. ;D
« Reply #9 on: February 11, 2008, 11:43:55 am »
Is the cabinet laminated or painted?  That will make a big difference.  Obviously can't just plug and paint a hole in laminate.
arcadefever
« Reply #10 on: February 11, 2008, 11:45:41 am »
I have a spare plug button from my old astro...
let me know if you want it ?  :cheers:
Jdurg
« Reply #11 on: February 11, 2008, 11:58:09 am »
In my initial CP, I screwed up drilling a button hole and had it 1/4 " too far south.  I plugged it with some scrap wood and wood glue, then let it completely dry.  After filling with "plastic wood" and sanding it smooth, you couldn't tell it was there.  I then redrilled and it is still quite solid.  (Of course, I wound up scrapping the entire CP and started over from scratch, but now I have a nice test panel to work with).
Donkey Kong High Scores:
1): 49,500
2): 35,600
3): 30,100
4): 29,400
5): 28,200
Kevin Mullins
    • Me on Myspace
« Reply #12 on: February 16, 2008, 07:14:39 pm »
For those that wish to know........
Happs part number 52-6212-00 or 52-6214-00 Button Hole Plug
http://www.happcontrols.com/pushbuttons/52621200.htm
I'm sure one of our BYOAC distributors can get them as well...... so go there first.   ;D
