Author Topic: Convert old SNES Arcade Controller to Mame?  (Read 2071 times)
PhoneLine
  • Last login:January 26, 2017, 07:24:08 pm
  • Keyboard Error. Press F1 to continue.
« on: February 09, 2008, 04:01:03 pm »
Hey all,
Recently was cleaning out a closet and pulled out my old SNES.  With it I found two arcade controllers I had purchased when SF2 first came out for the SNES.
Was able to find them after searching on google fo a bit...:
From what I remember these said at the time that they used real arcade parts, but being about 13, they just looked awesome and I wanted them instead of the joypads   :D
Anyone ever gutted these?  I'm curious if I was to get myself an ipac, if I could transfer both of them into a new 2 player controller for mame.
Seems they have enough buttons for my needs.  Joystick, 6 buttons and a start and select.  Start can stay start and select can be for credits.
Anyone know if it could be done, before I crack em open for no reason?  Not like I really plan on hooking up the snes anyways....   ;)
Also, for this setup (just simple two players) whats best, Ipac or mini?  I've been trying to gather up info, but my cabinet now just has a quad from slikstik on it, so this would be my first time making my own (from existing pieces)  :)
Appreciate any info!
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
Re: Convert old SNES Arcade Controller to Mame?
« Reply #1 on: February 09, 2008, 04:38:52 pm »
DaveMMR
« Reply #2 on: February 09, 2008, 04:40:15 pm »
I was about to post something similar.
Yeah, no need to hack anything (as a matter of fact, I'd leave it as is).  Use the adapter Boris pointed out.
Sir Auros
  • Last login:December 06, 2012, 12:13:00 pm
    • The Transformers Archive
« Reply #3 on: February 09, 2008, 04:48:35 pm »
I'm interested in getting some USB cables to use some of my old gamepads on my cabinet, but does anyone know of a place where they're cheaper than $22? I remember Lik-Sang used to have some for less (even with shipping), but they're out of business now.
PhoneLine
« Reply #4 on: February 09, 2008, 04:49:35 pm »
Pretty cool, thanks!
Anyone have any experience with these?  I'm curious as to how it assigns the buttons.  Will it show up as a joystick, and if so, will that work for me with mame?  I'm only use to dealing with mame where the joysticks and buttons are emulating keyboard strokes.
Thanks.
Kangum
  • Last login:February 25, 2018, 07:46:20 am
« Reply #5 on: February 09, 2008, 06:03:09 pm »
i have both the nes and the snes ones. the snes one works great but i have problems with the old nintendo version. im hoping its just the shoddy replica controller i got.
if you use the mala front end it supports joystick input natively. i just tested it using my snes and snes adapter. just set up what you want each controller action to do in the config dialog.
if the front end you choose only supports keystrokes you can use a program called joytokey. it converts joystick actions and buttons presses to keystrokes.
BORIStheBLADE
« Reply #6 on: February 09, 2008, 06:59:36 pm »
http://www.monoprice.com/products/subdepartment.asp?c_id=102&cp_id=10303
Sir Auros
« Reply #7 on: February 09, 2008, 11:01:12 pm »
Err, I meant old gamepad to USB converter cables. Not seeing those in your link to monoprice.  ???
protokatie
« Reply #8 on: February 09, 2008, 11:45:53 pm »
Boris was too busy trying to get Moose and Squirrel, and forgot what the context was.  :laugh2:
Either that or he was too busy with Natasha....
northerngames
  • Trade Count: (+18)
« Reply #9 on: February 10, 2008, 01:00:33 am »
are you wanting to use the buttons and joys from them and put them on another control panel or are you wanting to use them on a pc in the case there already in?
BORIStheBLADE
« Reply #10 on: February 10, 2008, 11:29:27 am »
who the hell are they?
Kajoq
  • Last login:June 14, 2024, 11:28:46 pm
« Reply #11 on: February 10, 2008, 11:37:15 am »
Boris and Natasha are from the old cartoon Rocky and Bullwinkle
BORIStheBLADE
« Reply #12 on: February 10, 2008, 05:36:48 pm »
 :banghead: Never watched it.
DaveMMR
« Reply #13 on: February 10, 2008, 05:43:48 pm »
But you've probably seen "Snatch", I assume.   ;)
BORIStheBLADE
« Reply #14 on: February 10, 2008, 06:01:25 pm »
I've heard about that movie. ;D
