Author Topic: Monitor Resolution Windows XP problems  (Read 1892 times)
hobosexual
  • Last login:October 21, 2009, 02:45:25 pm
« on: February 08, 2008, 03:00:39 pm »
Hello there!
I've had my MAME cabinet for nearly 3 years and recently had to replace my Wells Garner Monitor that burned out.
So I went with the 27"/29" MAKVISION TRI-MODE MONITOR http://www.happcontrols.com/monitors/49271500.htm.
Installation was a breeze, and I had to boot on an alternate monitor and change the res down, so the new monitor wouldn't freak out!
Sadly, this new monitor is only capable of displaying a max res of 640 X 480, and thats just fine with most emulators I run.
But it seems that WinXP has a problem with this and constantly switches to 800 X 600 after reboot(it also shows those annoying tip balloons that suggest you change the res!),
and I must go through the tedious process of plugging in a little monitor in to change the res back!
Now my previous monitor had a max res of 800 X 600, so maybe it is still assuming I have the old monitor?
Regardless, is there a way that I can FORCE XP to only display in 640 X 480? Is there like a registry setting or something that I can
try?
I've tried programs that set individual res for each user account, but that didn't work!
Here are my MAME cabinet specs:
Win Xp Media Edition SP2
AMD 1.7 ghz
Nvidia GeForce 6600 GT 256 MEG
1 Gb Ram
Sound Blaster 24-bit Live
27 " Makvision Tri-mode monitor WEBSITE: http://www.happcontrols.com/monitors/49271500.htm
Thanks a bunch, happy retro gaming!
Mark "Hobosexual" Wentland
northerngames
  • Trade Count: (+18)
Re: Monitor Resolution Windows XP problems
« Reply #1 on: February 08, 2008, 06:33:10 pm »
a quik res tool should lock it in at whatever you set it as.
ahofle
    • Arcade Ambience Project
« Reply #2 on: February 08, 2008, 06:40:51 pm »
Is that monitor digital?  Are you using any CGA or EGA resolutions?  I'd be interested in hearing more about that thing.
hobosexual
« Reply #3 on: February 09, 2008, 08:58:20 am »
It's an D-sub connection analog monitor, and I've plugged it directly into my video card's VGA port.
also in reply to northerngames: Is there any tool you'd recommend? I've tried Display Resolution Manager and locked in all my user accounts to 640 X 480, but still in no time one of my siblings some how changed the resolution even though I have Display settings access(among other things) disabled! (thanks to 1st Security Agent!)
northerngames
« Reply #4 on: February 09, 2008, 02:46:35 pm »
try google'ing quik res tool or ultimarc.com has one that may have more resolutions to pick from.
I am not 100% sure it would work for your trouble's but it should.
