Author Topic: New Project.....MAME TREK to boldly go where everyone else has before  (Read 6983 times)
Swatwolf
  • Last login:April 18, 2020, 02:27:44 am
Ok so it is corny and more than likely someone else has done it or something else like it. My basic idea is to use the Ultimate Arcade Template for the Cab, then a Custom MameRoom control panel with the few controls that I like or need. I have created the marquee and CP and some side art, any and of course all feedback is appricated painful or not.
I am also going to use some small EL panels under the CP to give the panel some blinking and look like the Star trek panels
Video Games Currently owned and running: Mania Challenge, X-Men (Children of the Atom), A.P.B.
In the works Mame Trek (Scratch Built), Donkey Kong Jr. (Just got a PCB for)
somunny
  • Is it hot in here?
Re: New Project.....MAME TREK to boldly go where everyone else has before
« Reply #1 on: February 07, 2008, 10:49:46 pm »
That cp is really great looking!  :applaud:  So great in fact, that it kind of dwarfs your marquee in its shadow.  There has to be some nice hi-res Trek art out there, somewhere for you to use.
Swatwolf
« Reply #2 on: February 07, 2008, 10:55:35 pm »
Well I had all sorts of different ideas such as what came on the original Star Trek Arcade Marquee, and had a few other ideas. I see your point, thanks for the feedback and I will look at it.
« Reply #3 on: February 08, 2008, 12:17:22 am »
Cool... you could use the grid effect from the holodeck - I think it could liven up the CP (especially if you tone it down the brightness)
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
« Reply #4 on: February 08, 2008, 02:47:04 am »
At last someone has the balls to produce a LCARS based Control panel. Looking great!! I personally wouldnt use EL to light the panel use UV LED's and connect em to an LEDWIZ or pacdrive. EL doesnt last long and begins to dull out after 14 days! Much better to use LED's and diffusing material (I use Hot Glue, great diffusion material!!!)
This cab will definetly secure your position in the "Star Trek Nerd" Hall of fame  ;D
When pixelated clipart just wont do, just call for Betty
spocktwin
  • Last login:January 11, 2026, 10:20:41 am
  • "Good Luck with That!!!" Timmy Turner
« Reply #5 on: February 08, 2008, 03:06:33 am »
I sir, salute you!!!!
You deserve an IDIC :applaud: :applaud:
Spock
Sherlock Holmes lives, just ask Watson
WaRpEd
  • Last login:December 03, 2022, 12:00:41 pm
  • The older I get the better it was!!
    • Warped products
« Reply #6 on: February 08, 2008, 08:38:10 pm »
I love it
Live long and prosper
There are three kinds of people in the world those that can count and those that can't.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Reply #7 on: February 08, 2008, 10:14:01 pm »
I love your control panel but don't really like your marquee that much.
Will your finished control panel show the trackball plate or is it just there for picture purposes?
That control panel would be awesome if it was back lit.
Not sure what would make a better marquee but I don't think the movie cover thing works, also maybe a later Star Trek font, one that thicker looking would stand out more.
Look forward to following this project.
Swatwolf
« Reply #8 on: February 08, 2008, 11:18:10 pm »
Seems like the consensus is that the CP does not match the Marquee....Not all that suprising if you look to the man hours behind the cp and side art to the hours on the Marquee.
I am always up for any suggestions and ideas for the Marquee, and also to add in the Trackball plate will be hidden uder the CP. The only main reason it is there is becasue of the CP program I was using.
Also to keep the role going here is my side art, hope ya all like  ;D
I guess since I am the Star Trek Geek..........Live Long and Prosper
RetroBorg
« Reply #9 on: February 08, 2008, 11:28:27 pm »
Cool that will look a lot better, what CP program are you usuing, is it CP Sketcher?
I like that! Though your Mame Trek isn't centred properly.
Swatwolf
« Reply #10 on: February 08, 2008, 11:33:59 pm »
Using both CP Sketcher and Custom Control Panel Designer kind of as multiple views for the same problem.
Ya I noticed that when I converted it.....kind of a bit to the right..but thnx and will keep working it up
Knievel
    • Knievel Kustoms
« Reply #11 on: February 09, 2008, 01:36:43 am »
Sweet looking CPO alright.
I've had an idea for backlighting a CP that I have yet to use. I think it would work well with your 'dash board' artwork.
Basically the idea is to use plexiglass as your CP material. One thick piece if you can find it would work best, or 2 thinner ones sandwiched and glued together. You would do all your joystick/trackball/button mounting as you normally would, and then apply your CP overlay.
Now the beauty of this is when you throw some lights in the CP box they would light up all 'gauge' areas, and your logos, etc. Sort of the same idea as modern pinball playfields. I don't think much light would make it through the black areas, you could always mask them off from underneath if so.
You'd have to experiment with lighting when you get to that point. LED's with an LEDWIZ making them all blinky would be really cool. :)
RetroBorg
« Reply #12 on: February 09, 2008, 01:03:52 pm »
I was thinking plexi too, the only problem I foresee are the graphics located around the joystick won't light up as the joystick base will prevent light from coming through.
nuka1195
  • Last login:April 18, 2020, 08:47:25 pm
« Reply #13 on: February 09, 2008, 03:26:45 pm »
Very nice.
Could you bottom mount the joysticks and mount leds above.
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« Reply #14 on: February 10, 2008, 11:33:04 am »
I like the CP. :cheers:
Swatwolf
« Reply #15 on: April 14, 2008, 06:07:43 am »
Ok finally have gotten back to work on this bad boy......decided to try a new marquee after seeing what others are and have done. I have just finished the wood working on the Ultimate Arcade 2 cab and will post pics soon. Here are the two ideas let me know how it looks and if the blue color on the type print looks good.
Also I decided to take leapinlew idea and make the bezel a holodeck looking grid with the yellow lines.
Still I am having problems with the illumination of the CP, dont want to give up on it but I dont want to break the back for a glowing background. I thought that the plexi panel might work out now just need to see about costs.
« Last Edit: April 14, 2008, 06:11:57 am by Swatwolf »
Franco B
« Reply #16 on: April 14, 2008, 10:45:15 am »
Awesomes  8)
Im using plexi inserts and LEDs in my CP in the joystick base area. Im using round plexi rod inserted into the top of the CP but you could route out parts of the CP top and insert rectangular etc plexi shapes into the top. You can then mount the leds from the bottom and if you bottom mount the joysticks they will hold the LEDs in place.
Ive just quicked edited a drawing from my thread to give you a better idea:
Kaytrim
  • I'm too nice a guy
« Reply #17 on: April 14, 2008, 12:57:31 pm »
I would love to see you light up that CP.  You can get some nice LEDs with resistors from this seller on eBay.  eBay Linky
kizer
    • Links4jeeps.com
« Reply #18 on: April 14, 2008, 02:07:44 pm »
Personally looking at your CP and your Marquee its going to be really hard to even match.
However my comment would be on that current Marquee with all the ships would to lower the text size and place them in the bottom left corner because the text is making the Marquee look cheap.
Or
Intergrate the art work onto say the enterprise so it doesn't look like a last minute slap on. I know its not a last minute thing, but it just doesn't compare to the quality of the image.
Swatwolf
« Reply #19 on: April 15, 2008, 02:27:39 am »
kizer point well made my wife who does not like arcade machines did not like it as much so I spent all night working with Adobe Illust, and made a LCARS marquee.....so I think that this will be my final concept I and I am going to move onto wiring soon
Doctor Ugs
  • Last login:May 14, 2011, 02:56:58 pm
  • Arcade addict since 1980
« Reply #20 on: April 15, 2008, 12:19:10 pm »
i'd go with the last marquee posted, fits the theme much better. Looks really sharp. Nice work
"My memory is so bad,
Alzheimer's would be an improvement!"
My Project Thread, 2 Mame Cabs.
MK3FAN
« Reply #21 on: April 15, 2008, 07:45:20 pm »
Great idea for a cab! It makes me want to go out to the club with these guys..
Swatwolf
« Reply #22 on: April 15, 2008, 10:49:49 pm »
geeks of star trek unite hehe, nice  :applaud:
Lutus
  • Last login:August 23, 2012, 10:58:10 am
  • "I love my Power Glove. It's so BAD!"
« Reply #23 on: April 15, 2008, 11:28:18 pm »
Great marquee.  Fits MUCH better!
TNG!
www.justin.tv/lutus8
www.encoreinstruction.com <-- for my fellow musicians
Havok
  • Trade Count: (+17)
« Reply #24 on: April 15, 2008, 11:46:58 pm »
TNG!
TOS!
 :P
Lutus
« Reply #25 on: April 15, 2008, 11:57:46 pm »
TOS is pretty awesome though.
Running time on TNG was around 42-44 minutes an episode, but when TOS aired there were less commercials and their run time was round 52 minutes IIRC.
Does anyone else think that TOS felt SOO much longer per episode even though it was less than 10 minutes more, it just felt like a lot.
I am rambling now..... must fight back sleep..........zzzzzzzzzzzzzz
Swatwolf
« Reply #26 on: April 16, 2008, 12:55:19 am »
Seemed like the TOS had a bit more story (not always a good story) since the special effects were not as good. In the TNG and others they used alot more special effects (which I still liked) but it was almost a filler rather than what they used to have.
Kaytrim
« Reply #27 on: April 16, 2008, 10:37:23 am »
Ok you have all the artwork set up now let's cut some wood. 8) btw I like that last marquee much better you now have a complete set.
TTFN
Kaytrim
Cero21
  • Last login:February 23, 2016, 11:04:44 pm
« Reply #28 on: April 20, 2008, 10:44:09 pm »
Wow, you've got some serious skills.   :notworthy:
Love the last marquee as it goes really well with the cp.  Keep up the good work!
amadama
  • Last login:September 29, 2019, 04:44:52 pm
« Reply #29 on: April 22, 2008, 11:32:14 pm »
That is a wonderful marquee you designed there! Why do you not just say Star Trek instead of Mame Trek? Leave the multiple arcade machine emulator text below it however.
Alex
Swatwolf
« Reply #30 on: April 24, 2008, 09:03:09 am »
Well just kind of came up in a conversation at work and kind of liked the Mame Trek idea, just to set it apart from a star trek title.....guess wanted to go geek 100%     ;D
Swatwolf
« Reply #31 on: August 06, 2008, 08:31:05 am »
Update, cabinet is completed will post pictures of finished bare wood shortly. Now trying to workout the illumination on the CP and wiring.
