Author Topic: darn, light gun just stopped working!  (Read 1963 times)
vertygo
  • Last login:September 20, 2015, 03:19:59 pm
« on: February 04, 2008, 11:56:10 am »
Man, I just moved my cab into the house.. was working perfectly, then suddenly the second lightgun stopped working!  :angry:
I switched the gun1 and gun2 connectors, and the same gun failed on the new port.. so I'm thinking the jamma board is fine, it's just the gun. I thought maybe it might be the IR sensor, but then I realized it doesn't even trigger the 'white screen' flash or sound effect.
Any help on how to diagnose what's wrong or how to fix it would be very much appreciated.
Fozzy The Bear
  • Handbags at dawn in here!!!
  • Last login:September 18, 2011, 11:29:59 am
  • It's Been One Of Those Days... Don't Ask!
Re: darn, light gun just stopped working!
« Reply #1 on: February 04, 2008, 12:05:42 pm »
Difficult to diagnose it until you tell us what cab it is, what lightguns you have etc etc etc... At the moment, I'd guess it's a wire break in the gun cable somewhere. Probably the ground line.
Best Regards,
Julian (Fozzy The Bear)
« Last Edit: February 04, 2008, 12:07:22 pm by Fozzy The Bear »
Most bottles and jars contain at least twenty-five percent recycled Pacman.
And research indicates that Space Invaders are strongly attracted to people who have recently eaten meat pies.
vertygo
« Reply #2 on: February 04, 2008, 12:27:12 pm »
Sorry, didn't realize it would make a difference.. it's a Police Trainer cab.. not sure what guns they are.. pretty generic looking, no recoil action.
Thanks Fozzy, I assumed it would involve dis-assembling it, just wanted to make sure first.
Fozzy The Bear
« Reply #3 on: February 04, 2008, 10:09:08 pm »
Start with taking the gun apart.... There's nothing complex inside them, it may be that the cable has just come unplugged inside the gun. It happens sometimes.
If that doesn't cure the problem, then remove the cable from the gun and the machine and buz through each wire with a meter. you should find the one that's gone down.
If that still doesn't find the fault then try reflowing the solder on the plug inside the gun, where it connects to the input output PCB. The solder joint on them has a habit of breaking at that point.
Best Regards,
« Last Edit: February 04, 2008, 10:13:27 pm by Fozzy The Bear »
