Author Topic: Is it possible to install windows on a usb drive??  (Read 1789 times)
havic626
  • -banned-
  • Last login:August 05, 2012, 05:11:42 am
« on: February 04, 2008, 08:47:50 am »
i would like to know if anyone out there knows if its possible to install windows on a  usb drive.  i would like to have a mame cab, but would rather have a usb drive installed instead of a regular ide/sata drive.  If anyone know how, can someone plz explain? ???
NOP
  • Last login:September 19, 2017, 08:22:27 pm
  • I stole my avatar.
    • winterMAME
Re: Is it possible to install windows on a usb drive??
« Reply #1 on: February 04, 2008, 10:17:01 am »
While I'm sure you could, you will likely wear out the drive in a very short time doing this, unless you were able to get a ramdrive up and running and use that for the swap file.
ya see, flash has a nasty habit of wearing out, typically after about 100k writes.  windows writes A LOT.  Just sitting there, windows always seems to be doing something to the drive.
Flash based hard drives (SSD's) that are coming out now utilize a wear leveling methodology to spread out the writes across the entire drive, thus making it last as long as a regular hard drive would, but these little USB drives are not quite that smart, and you can blow through one in less than a month if you do too many writes to it.
I did a DOS based machine running on a 1gig compact flash->IDE adapter and it was really cool.   A simple O/S like that is about the only thing I'd suggest (for now) attempting to do on a solid state device.
As for how to do it, I think I would first get everything installed and confgured on a regular hard drive, then use a norton ghost or similar application and see if you can mirror the installed drive onto the USB device.  From there it really depends on your motherboard's BIOS to be able to treat that USB device as a real hard drive and be able
to boot to it.
CF->IDE adapter cards work really well for this-no BIOS changes at all, and your machine sees the CF as a normal hard drive.
-jeff!
havic626
  • -banned-
« Reply #2 on: February 04, 2008, 11:04:32 pm »
wow i had no idea......thnx!!
SavannahLion
« Reply #3 on: February 06, 2008, 01:12:07 pm »
  • Last login:February 01, 2026, 01:32:52 pm
« Reply #4 on: February 09, 2008, 01:17:09 am »
I wasn't gonna comment on this one, but I can't stay quiet on this.  Xp will run prefectly fine on a usb drive and while it will wear out slightly quicker (keyword slightly) it should last way longer than a few months.  The key is to completely disable swap-space and dr. watson in xp as well as system restore.  After that 99% of those "constant mystery writes" will disappear.
Swap space is NOT required to run xp in any way shape or form.  With that being said, the machine in question will need a mandatory 512 megs of ram.  If you want to run anything fancy on it upgrade to a gig.  Nothing but the most intensive programs use more than 512 in windows and even the biggies (photoshop, movie editing, ect) rarely use more than a gig.
NOP
    • winterMAME
« Reply #5 on: February 10, 2008, 06:45:06 pm »
Very nice information howard!
I think that knowledge is worth its weight in gold.  Maybe that should be wikiafied.
I still stand by my statement that (without the above tweaks) you'd nuke your flash drive in a very short amount of time though. ;)
-jeff!
