Author Topic: Mala Showing emuviews video's in snap window  (Read 6040 times)
kegger
  • Last login:April 10, 2011, 10:59:14 am
  • There are no unsingable songs....
« on: February 01, 2008, 12:51:40 pm »
Hello, I would like to show the attract videos where the snap shots would normally go.
Check out this video it was probably made from a member from here.
Banditt
  • Last login:June 21, 2020, 04:19:43 pm
Re: Mala Showing emuviews video's in snap window
« Reply #1 on: February 01, 2008, 03:03:08 pm »
I found this on another page:
Using MALA v1.04 in this arcade cabinet. I didn't want a layout with a spot for videos and another for snapshots. I wanted it to show screenshots as the selection moves through the list but show videos only when I stop. The way this was done was using MALA's layout editor to have the area for snapshots and videos to take up the same space but put the videos in Z-order on "top". Then in the MALA config, add a 1200ms pause so that the videos show only if you stop and pause.
I have never used the Mala Editor, but I think that's the way to do it
kegger
« Reply #2 on: February 01, 2008, 05:33:17 pm »
Thanks, I will make some new layouts tonight but one thing that I don't think I understand is when you say Z order I get the have the video space on top of the snap space and put the pause in not sure about the Z order though?
Banditt
« Reply #3 on: February 01, 2008, 06:18:58 pm »
In the layout editor click Objects and then Z-Order. Looks like if it is lower in the list it will be in the front. Just make sure the Video is lower than the Snap
(of course I can't test at work so maybe it's higher  ;) )
I am going to be messing around with it as well - If you figure out where to put the pause in the config post it here.
« Last Edit: February 01, 2008, 06:23:01 pm by Banditt »
kegger
« Reply #4 on: February 04, 2008, 05:13:25 pm »
The delay is under Gui then Options tap check the box that says"Enable video display delay" then set at 1200ms
And thanks for your help on this I got it working. :cheers:
only prob. now is all the videos arent being recognized by the codec or even WMP.
So now I don't know if I have to reencode them or what to do.. ???
« Last Edit: February 05, 2008, 01:07:45 pm by kegger »
shock_
  • Last login:January 30, 2020, 06:23:29 pm
  • In Brisbane, it's GMT+10 all the time.
« Reply #5 on: February 08, 2008, 02:29:29 am »
Due to mysteries of the universe, it matters not about Z order for videos.  They will only be on top no matter what.
Don't re-encode the videos, they work fine in MaLa - it's your system. Do a search on MaLa xvid and you'll turn up heaps on videos not working, and what you can do about it.
In MaLa "Options » GUI » Options » Display Delay (scrolling)" set exceptions to snap and you'll have that snap in place while you scroll, and then the video when you stop.
loadman
  • Moderator
    • MaLa
« Reply #6 on: February 08, 2008, 04:11:18 am »
Correct. A limitation of the video plug that MaLa uses
