Author Topic: mamewah Error!! Need Help.  (Read 1472 times)
cleric
  • Last login:June 07, 2003, 05:39:19 pm
« on: May 18, 2003, 11:00:49 am »
Hi
I have install mamewah when i run it for the first time everythings works fine. But when i quit the program and try to run it again. It give some kind of error saying "illegal operation bla bla"..
when i unistall i run it again works fine...2nd time give this error again.
Can u help me??'
2nd Question - How can we run neo geo roms from Mame emu ?  the other mame roms works fine but all neo geo roms it say it miss some files. I think is the neo geo bios files but i have the neegeo.zip (bios roms) in the roms directories. were i must put this files on ??
« Last Edit: May 18, 2003, 11:20:33 am by cleric »
Re:mamewah Error!! Need Help.
« Reply #1 on: May 19, 2003, 06:20:35 am »
Cleric:  Are you French/Belgian/Dutch??  There is a bug in MAMEWAH which means it doesn't like the decimal seperator from these countries (& possibly others).  Go into Control Panel > Regional & Language Options and check your decimal symbol...if it is set to ',' then either a) change it to '.' or b) edit your MAMEWAH.CFG file and alter the Font Size setting to an integer (eg 10).
If this is not the case then let me know & I'll try and find the problem.
Neo Geo roms should work fine as long as you have the neogeo.zip in your ROMs folder.  Just make sure that you have the latest version of neogeo.zip, it has changed a number of times (I suggest re-download it just in case).
Hope this helps...
cleric
« Reply #2 on: May 19, 2003, 07:14:26 pm »
IS WORKING NOw!!!  ;D
Thank U.
« Reply #3 on: May 20, 2003, 06:15:48 am »
Glad it worked :)
