Author Topic: Need help setting B+ on Pentranic 1525 monitor  (Read 2633 times)
Grauwulf
  • Last login:July 27, 2009, 03:42:44 pm
  • Button Masher
« on: January 29, 2008, 07:09:50 pm »
Hey all, I have a Pentranic 1525 monitor here that I finally managed to get working, but I would like to check and adjust the B+. I know someone has been messing around with every single knob on this thing. I have the schematics, but they don't show the B+ value anywhere on them, or show a point to test it. Can anyone get me pointed in the right direction? This is a CH288 chassis BTW.
www.wolfelectronics.ca
Cap Kits for Canadians!
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
Re: Need help setting B+ on Pentranic 1525 monitor
« Reply #1 on: January 29, 2008, 10:49:44 pm »
varies somewhat per mfg .   regulated B+ still likely NOT to exceed 130V.
smps in this unit ??
qrz
Grauwulf
  • Button Masher
« Reply #2 on: January 29, 2008, 11:43:54 pm »
Yes, it is a SMPS monitor. There isn't even a B+ test point that I can find so that I can see where it is.
qrz
« Reply #3 on: January 30, 2008, 12:23:04 am »
with pwr OFF, take a continuity test from the collector of the h out xistor to the diodes in the supply .
eventually, you will find the main B+ rectifier . this can be ur test point...
some mfgrs don't want just anyone pokin' around their chassis's  ;D
qrz
Grauwulf
  • Button Masher
« Reply #4 on: January 30, 2008, 06:32:39 pm »
If they didn't want anyone messing with it, they should have glued the damn adjustment pot in place. *lol*
Thanks for your help.
James
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #5 on: January 30, 2008, 06:35:47 pm »
First off Pentranic... or Makvision??
If Pentranic the 15 would have indicated an SVGA chassis, the 25 is the size in inches... don't think so they never did an SVGA 25" that I know.
Makvision, the 15 means - 15Khz, (standard res) and again the 25 is the size.
I am pretty sure you have a standard res chassis, it has a grey plastic frame and is about 10x8 inches, rough guess.
Oh if so, D501 cathode with a crosshatch 113~115 volts DC.
By all means if you ever have occasion to drift from St. Thomas towards Kitchener, give me a call if you would like to drop by the factory.
Good Luck
Rick Nieman
President- Nieman Video Displays
www.Niemandisplays.com
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
www.niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
Grauwulf
  • Button Masher
« Reply #6 on: January 30, 2008, 09:11:31 pm »
The monitor is branded Makvision, but the chassis is silkscreened Pentranic. It is a 15khz 25" monitor with chassis CH288. I will get it back up on the bench and check what the B+ is. I tweaked it to get the best looking picture I could, but I would really like to know what it's set at.
I will certainly take you up on your tour offer some day Rick, I'm out of work right now, so it would be a nice way to spend a few hours of an afternoon. :)
