Author Topic: Pentranic model #1135 monitor  (Read 3642 times)
beanman
  • Last login:April 21, 2008, 06:25:24 pm
« on: January 29, 2008, 06:45:38 pm »
Hello all, I have a Pentranic model#1135 monitor with a manufacture date of 4-16-96. I have not capped it yet. It has a horizontal line across the center of the tube. I believe it is a 33 inch monitor. Any help pointing me in the right direction will be greatly appreciated. Thanks in advance.
grantspain
Re: Pentranic model #1135 monitor
« Reply #1 on: January 29, 2008, 06:54:52 pm »
have you a pic of the chassis?
qrz
  • Last login:October 24, 2015, 03:04:15 pm
  • wrangling electrons since 1978
« Reply #2 on: January 29, 2008, 10:52:03 pm »
sounds like failure of the vert output stage ...
look for domed caps , burnt components,  etc..
seeing a print would be helpful
qrz
Rickn
  • Last login:May 08, 2020, 01:32:28 pm
« Reply #3 on: January 30, 2008, 07:17:52 pm »
Yes could be vertical output transistor, most likely... But could be Vcc for the vertical which is supplied by the flyback.
It is rectified by D304, look for 18 volts at L401/C402.
If you need a schematic, visit my website and go to the standard res CRT monitor. It is a generic schematic for the same board that I use.
Hope this helps, but feel free to contact me direct phone or e-mail below.
By the way we can also offer you a quote to repair the board.
Good Luck
Rick Nieman
www.niemandisplays.com
519-621-1722
Always happy to help.., for the best in displays
Rick Nieman
Rick@Niemandisplays.com
1023 Rife Rd Cambridge, Ontario Canada N1R5S3
519-621-1722
beanman
« Reply #4 on: January 30, 2008, 09:01:46 pm »
Wow thanks for all the help so far. I wanted to put some pics on. I might take you up on that repair. Hope the pics come out ok.The shots of the tag didn't turn out very good but it says: MODEL # 1135
        SERIAL #11310
        DATE MANUFACTURED: 4-16-96
        INPUT VOLTAGE - 110-260 VAC
        MAXIMUM WATTAGE - 130W
Thanks again for the help.
qrz
« Reply #5 on: January 30, 2008, 10:59:04 pm »
if the schematic here  ( www.niemandisplays.com/nvd%20ch-288%20cga%20only.pdf  ) matches ,
check R336, d401, d399, ic3, c393,c398  and for kicks, d407/c961
r336 and d401 (and t401) comprise the 25-30v source for the vert output .
note : failure of c393 will produce vert foldover.
TNX Rickn,    repair techs really LIKE free info   :applaud: :applaud: :applaud:
qrz
beanman
« Reply #6 on: April 21, 2008, 06:20:15 pm »
Thanks everyone. Just wanted to update this repair. I ended up sending the board for repair and was informed of the time of death :cry: But finally fixed the monitor with a new chassis :cheers:I am not sure if I can give props on here so I wont. Thanks again
