Author Topic: VGA/DVI to Component Video Card?  (Read 2426 times)
SparkyGoBlue
  • Last login:August 01, 2022, 04:06:45 am
« on: January 27, 2008, 05:04:26 am »
I picked up a Panasonic TV with component input for my cab today, but I can't get it working with the computer.  I'm using a VGA to component cable I got from monoprice.  I'm hooking it up to my on board video card (nvidia 6150SE). S-Video is working fine with the TV, though the picture is less than stellar IMO.
From my research, I'm gathering that my video card may not be able to work with component video.  Is this right, or is there something else going on?  Any recommendations on a card that would work well with component input? ATI seems to be pretty popular here.
Edit: Just realized my mobo only has PCI Express, no AGP slot, so that may limit my choices.
« Last Edit: January 27, 2008, 05:23:42 am by SparkyGoBlue »
northerngames
  • Trade Count: (+18)
Re: VGA/DVI to Component Video Card?
« Reply #1 on: January 27, 2008, 10:27:31 pm »
they still have them in pci also but make sure you feed the tv the right res. from the pc.
IG-88
« Reply #2 on: January 27, 2008, 10:35:10 pm »
Sorry to jump the thread here, but what exactly would be a good "res" for the TV? I've been using a AIW 7800 and going from s-vid to a RF modulator to coxial on my old TV. Games don't look to bad, I just can't figure out how to stretch the image to fill the whole screen.
-HarumaN
brock.sampson
  • Last login:May 31, 2018, 10:11:41 pm
« Reply #3 on: January 28, 2008, 01:37:56 pm »
I'm assuming you bought the same dongle I did, http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10419&cs_id=1041901&p_id=2398&seq=1&format=2.  I don't think that is compatible with your video card.  Quote from monoprice site.
Compatible video cards include: ATI ALL-IN-WONDER RADEON 8500, 8500DV, RADEON
9500, 9550, 9600, 9700 & 9800 series of video cards.
DOC! YOU HAVE A TABLE OVER THERE WITH A SIGN THAT SAYS, "LASER DEATH RAY BARGAIN BIN!"
SparkyGoBlue
« Reply #4 on: January 28, 2008, 01:41:24 pm »
No, I got this one.
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10235&cs_id=1023504&p_id=2508&seq=1&format=2
Any difference?
brock.sampson
« Reply #5 on: January 28, 2008, 01:55:51 pm »
I don't think that is going to work but I'm not sure.  Another quote from monoprice.
(*)The Cable Not Support your Computer Monitor Video
Port, or Y , Cr, Cb Video. Your Video Source Must Provide a YpbPr Component Video
Signal form the DVI-I Video Ports to Use Cable
I did some quick looking for the 6150se and I didn't see them mention this capability anywhere.  Found this on the nvidia site.
In conjunction with SDVO to TV-Out conversion chip on the motherboard or on the riser card in the PCI-Express slot enables analog TV-Output. In conjunction with SDVO to DVI-Out conversion chip on the motherboard or on the riser card in the PCI-Express slot enables DVI-Out connectivity to flat-panel monitors.
Feature only available for GeForce 6100/ nForce 430 and GeForce 6150SE/nForce 430 Motherboards manufactured after August 2006.
SparkyGoBlue
« Reply #6 on: January 28, 2008, 02:11:01 pm »
Thanks for the help.  I'm pretty sure the 6150SE isn't able to send a component signal to the TV.  I just ordered an ATI Radeon HD 2400 Pro which should take care of the problem.
