Author Topic: Decased TV mounting question  (Read 4793 times)
Gehrig
  • Last login:January 11, 2009, 12:21:06 pm
« on: January 20, 2008, 07:32:08 pm »
So, I am planning on using a decased 24" Toshiba tv as my arcade monitor.  The TV doesn't fit when cased.  More on that later.
The 4 small mounting brackets that are attached to the (decased) TV are at the corners.   The problem is that the brackets aren't flush with the back or the front of the TV.  So, simply putting 2x4's across (inside the cabinet) to attach the monitor won't work.  I think I would need to put something at 45 degree angles for each bracket.  The other thing that concerns me, is that brackets are pretty small.
The mounting brackets are 21" across from each other.  The space in the cabinet is 24".  The cabinet is an old Atari cab (particle board).
Now my other option is to keep the front part of the case attached to the tv.  Then saw about an inch off of each side of the case.  But, not having the back of the case on will be a problem.  Since I need to mount the TV back on an angle, there will be too much weight pushing down on the logic board.   Plus the case will bend.  So, I would still need a way to secure the front.
Basically, I am kinda stuck on what to do.  Any suggestions would be appreciated.
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
Re: Decased TV mounting question
« Reply #1 on: January 23, 2008, 12:23:25 am »
if you cant make it fit with the trimmed case on it, IMO - ditch it for this idea. Those brackets do look pretty small, and I would be afraid of relying on the old particle board to hold it. If you could create a new wood bezel that could handle the angle problem, I would think that to be ok. For whatever reason, I didn't understand the angle issue - so this may make no sense. It's also late.
good luck!
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
IG-88
« Reply #2 on: January 26, 2008, 11:13:22 pm »
There has to be a way to to use this bad boy. I like the bezel idea that Daniel B. had. You could make the outer dimensions the exact size to fit your cab and the inner size to fit the monitor. I'd use plywood for that tho, it being stronger for the tabs to bolt too. Maybe you could make a couple out of cardboard to get a idea on what you need ?
-HarumaN
sealslayer
  • Last login:March 18, 2014, 04:41:30 pm
  • Why screw when you can bolt
« Reply #3 on: February 03, 2008, 04:43:10 pm »
you could always build a metal frame like I did for my upright
« Last Edit: February 03, 2008, 04:44:46 pm by sealslayer »
Gehrig
« Reply #4 on: February 04, 2008, 05:22:42 pm »
Thanks for the replies.  I called a a local guy that fixes arcades and picked up a monitor mount/frame.  So, now I should be able to put a 2x4 straight acroos the cabinet to mount the frame to.  Now I am trying to figure out the best way to mount the 2x4 across..but I have some ideas.
IG-88
« Reply #5 on: February 04, 2008, 09:53:23 pm »
Make sure you post some pics on how you did it.  ;)
-HarumaN
SteveJ34
  • Trade Count: (+9)
  • Last login:January 06, 2024, 12:29:40 am
« Reply #6 on: February 06, 2008, 01:36:24 am »
Wood glue might be the simple answer to secure pieces to each side of the cab without needing screws through the outside of the cabinet to mount the cross member to.
You could glue, clamp, and wait reasonable period and the joint created would be more than strong enough without screw support.
ivwshane
    • My first mame cab! (WIP)
« Reply #7 on: February 14, 2008, 02:03:23 am »
Sweet!!!
I asked this question in the monitor forum and never figured the info i needed would be here.
I like it!
Quick question: How did you mount it to the cab?
« Last Edit: February 14, 2008, 02:04:56 am by ivwshane »
ivwshane
« Reply #8 on: February 15, 2008, 01:41:33 am »
I've found another possible solution for mounting the monitor:
http://fredmame.blogspot.com/2007/11/cabinet-construction-starts.html
I might build it as one whole assembly which would allow me to safely remove the whole thing easily.
IG-88
« Reply #9 on: February 15, 2008, 07:33:14 am »
Thats exactly what I was talking about earlier. I knew I'd seen that somewhere.
-HarumaN
TOK
  • The Game Always Wins
« Reply #10 on: February 15, 2008, 07:53:20 am »
The wooden surround with the handles is how my generic Dynamo cab was made. The cool thing is that the wooden monitor mount is square, so you can spin the monitor from horizontal to vertical in minutes.
sealslayer
« Reply #11 on: February 21, 2008, 01:15:56 pm »
Sweet!!!
I like it!
Mine is bolted in from the sides as I later covered the sides with laminate, you could easily use the same sort of frame and drill holes all the way round it then screw it to your cabinet, just make sure that the back of the monitor is supported.
ivwshane
« Reply #12 on: February 21, 2008, 02:11:04 pm »
When you say make sure the back of the monitor is supported what exactly are you referring to? The back of the glass or where the electronics are held.
