Author Topic: Button Halo question  (Read 1442 times)
BORIStheBLADE
  • Last login:February 03, 2012, 10:53:59 pm
« on: January 20, 2008, 11:55:38 am »
So following Knievels guide I have some questions.
What is a good size to to make the inner glow?
Are you choking 100%?
technique- precise?
What opacity is good for the halo?
Trying to get the drop shadow going I don't see any results. What kind of setting do I use under that too?
« Last Edit: January 20, 2008, 12:45:56 pm by BORIStheBLADE »
BORIStheBLADE
Re: Button Halo question
« Reply #1 on: January 20, 2008, 12:12:56 pm »
Ok I got drop shadow to work. I was able to see what was doing what if I did it in a white background.
For drop shadow what are you guys doing for spread and size? Are you keeping opacity to at the same opacity as the objects you created?
