Author Topic: MAMEWAH Q: Execute program before Mamewah loads Mame game  (Read 3244 times)
brian23
  • Last login:September 07, 2011, 03:52:01 pm
« on: January 16, 2008, 01:42:05 pm »
I have a spare one of these at work: http://www.signal-tech.com/prod_view.cfm?sku=TCL418R-FD. It is normally used for displaying fees, but can display text. It only fits 8 characters statically, but if you exceed 8 characters then it will scroll the text. I currently use Mamewah for my frontend. Is it possible to execute a program before Mame loads and pass the game name as ASCII to my program on the command line, i.e. ShellExecute().
thanks
unclet
Re: MAMEWAH Q: Execute program before Mamewah loads Mame game
« Reply #1 on: January 16, 2008, 02:33:27 pm »
I am pretty certain MameWah allows you execute commands before Mame starts the selected game.   Look in your INI file associated with the emulator and you should find a line which states "pre_emulator_app_commandlines".   This line can list commands which should be executed before starting the emulator.
If I remember correctly, MameWah indicates the rom name with [name] and the emulator name with [emuname] but I am not sure if MameWah has knowledge about the actual Mame "game name" ..... which is what you most likely would like to display instead of the Rom name.
I am sure someone here will be able to help you figure this out ..... does not seem to hard.  I have just not worked with MameWah for a couple of years now.
« Reply #2 on: January 18, 2008, 08:37:45 am »
Yes thats correct, and Mamewah can send the game description.  You would need something like this:
pre_emulator_app_commandlines c:\display.exe [description]
roger
  • Last login:July 31, 2011, 09:40:22 pm
« Reply #3 on: January 15, 2009, 02:07:53 pm »
Is there also a way to execute a program when the platform is switched in MAMEWah? Specifically, I want to display the name of the current emulator upon switching the platform, e.g. if I switch from MAME to VICE, I would want to show "VICE" on my external display. MAMEWah already works well for sending game information to the display when a game is launched, but when no game is running, I would like the emulator name to be displayed.
« Reply #4 on: January 20, 2009, 07:01:41 am »
Hmm not currently possible. Although some people use a seperate app to monitor the Mamewah (invisible) window caption - this contains info in the following format:
MAMEWAH - Emulator Title: Game Description (Romname)
This could be done but I have no idea about the software to monitor this info - I'm sure someone on here must know...
roger
« Reply #5 on: January 20, 2009, 12:44:01 pm »
Thanks for responding. I will look into that.
Is there a chance that it might me possible in the near future (cough, cough, feature request, cough)?
It would be great if there were directives like "emu_enter_commandlines" and "emu_leave_commandlines" in the emuname.ini configurations. MAMEWah can already play sounds when the platform is switched. Being able to perform other actions at these events would be a great addition.
roger
« Reply #6 on: January 22, 2009, 02:45:47 pm »
Some information on how to monitor MAMEWah's window caption can be found here:
http://www.mameworld.info/ubbthreads/showflat.php?Cat=&Number=178475&page=0&view=expanded&sb=5&o=&fpart=1&vc=1&new=#Post178475
