Author Topic: Need help, re : Control Panel 5/8 MDF  (Read 5754 times)
darkje
  • Last login:May 06, 2008, 03:26:10 pm
« on: January 15, 2008, 09:27:24 pm »
I'm trying to locate a sheet of 5/8 MDF locally with no luck at all to build my control panel top.
I tried several lowes, home depots, local lumber yards, noone has it or can get it!
The only thing that comes close is a 5/8 sheet of poplar, it looks like it's build from 3 layers of wood, would that work?
Or does anyone have any tips where to get a sheet of 5/8 thick mdf? I'm following saint's book but I'm now stuck on that part =/
Thanks for reading
sstorkel
  • Last login:November 08, 2011, 09:04:03 pm
Re: Need help, re : Control Panel 5/8 MDF
« Reply #1 on: January 16, 2008, 11:07:58 am »
I use a lumber yard that cater to custom kitchen cabinet builders when I want stuff like that. They either have it in stock or will special-order it for me. I would think that any full-service lumber yard (e.g. not Lowe's or Home Depot) should be able to do the same.
fixedpigs
  • Last login:August 19, 2025, 01:29:35 pm
  • warning: drew can't handle my avatar...
« Reply #2 on: January 17, 2008, 12:17:56 am »
i just made a router sled and made a section of 3/4" mdf into 5/8"...worked like a charm... :cheers:
darkje
« Reply #3 on: January 17, 2008, 11:20:42 pm »
Thanks for your comments, I found a do it yourself type store that caters to woodworking and they were able to order me a sheet!
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« Reply #4 on: January 21, 2008, 11:54:59 am »
Why do you need 5/8" and not 3/4"?
shardian
« Reply #5 on: January 21, 2008, 01:26:45 pm »
Match a 5/8" CP top with a 1/8" piece of plexi and you have a 3/4" top that lines up with T-molding.
« Reply #6 on: January 21, 2008, 02:29:47 pm »
Lowe's tends to use metric fractional sizes on their sheets... if you run the conversions on whatever size they have, they may actually be carrying something very very close to 5/8, but they have it listed as something like 21/32".
sstorkel
« Reply #7 on: January 22, 2008, 01:54:12 am »
Actually, it has nothing to do with metric measurements. Much like a 2x4 isn't actually 2" by 4", plywood which is "nominally" 3/4-inch thick is in fact only 21/32 inches thick.
Note that MDF doesn't follow this rule. A piece of MDF sold as being 3/4-inch thick is actually 3/4-inch thick.
« Reply #8 on: January 25, 2008, 03:21:07 pm »
Figures.  I asked one of the Lowe's monkeys about it and that's what he told me... note how much thought I apparently put into his explanation.
aszurom
  • Last login:October 14, 2013, 05:00:14 pm
« Reply #9 on: January 27, 2008, 08:15:35 am »
Here's a thought...
If your control panel top sits atop a box made from 3/4 mdf, you could just router 1/8 off the outer 3/4 where it meets the box it's sitting on.  The panel would fit down into the box 1/8, but the edges would be 5/8.  Has the potential advantage of anchoring the top better than hinges alone.
I dunno, I just made that up but I might try it on my own CP.
purpledrillmonkey
  • Last login:September 27, 2011, 02:50:08 pm
  • PRESS P1 START
« Reply #10 on: January 27, 2008, 08:00:04 pm »
Here's a thought...
This would only work if the edges of your CP top are designed to be square with the CP box sides, although it is a great idea.
