Author Topic: For Sale: Hollow joystick shafts, LED Lit for Sanwas/T-Sticks + More  (Read 20011 times)
Franco
I have some hollow joystick shafts for sale suitable for mounting an LED in or adding a top fire button to a joystick.
The shafts I have at present are for Sanwa JLWs and have a 6mm thread which screws into the Seimitsu LB-39 ball tops. The ball tops can be purchased from arcadeshop.de or from Lizardlick (scroll to the bottom of the page).
The shafts are available as a plain hollow shaft or ready wired with a modified LED and wire and suitable resistors for 5v or 12v applications. I can wire the shafts to your needs eg in series/parallel from a 5/12v source, singularly for use with a LED wiz or similar or I can also daisy chain the cathodes etc for use with an LED Wiz.
The following two photos are of the single hollow shaft and of a shaft with a shaft with a mounted modified LED and ready wired with a resistor:
I can currently wire the shafts with blue, red and green LEDs. I have ordered some yellow LEDs for a customer and they will be arriving shortly so they will also be available. If you require a different colour I will also try to source some for you.
The following photos are of blue, red and green (with the lights on and off) 8000MCD LEDs mounted with a clear LB-39 ball top. Unfortunately my camera is a bit crap and doesn't do the colours justice. You can see every bubble in the balls and they really do look beautiful (if I do say so myself.
The pictures look nice but the blue is really a lovely medium intense blue, the green is really emerald and the red is lovely too.
Pricing is as follows. The shafts on there own are $10/£5 each. If you require them wired with an LED and resistor add $5/£2.50 to each shaft. Extra wiring/resistors may be slightly more expensive depending on complexity.
If you want a cheaper option you can just buy the shafts and wire them yourself. You can use my guide here to help you if you need it.
At the moment I can get the shafts for Sanwa JLWs, JTFs and Ultimarc T-Sticks as I can take the dimensions of the sticks that I have but I should be able to make them for most other joysticks within reason, even the Ultimarc 360s  ;)
I can also supply the shafts in stainless steel or brass.
If you are intrested feel free to post her, PM or email me.
I will also be adding some more products soon including stainless steel (or brass) dustwashers (in some nice designs), stainless steel button bezels, (either single button or 3/6 button array), some very nice fan/speaker guards amongst other projects in the pipeline.
waveryder
  • Last login:July 14, 2011, 04:26:17 am
  • I Troop, therefore I am
    • BubbleGum Custom Art
Re: For Sale: Hollow joystick shafts, LED Lit for Sanwas/T-Sticks + More
« Reply #1 on: January 16, 2008, 08:51:50 am »
I can vouch for these. Francos hollow shafts are better and stronger than the originals!!
When pixelated clipart just wont do, just call for Betty
Grasshopper
« Reply #2 on: January 16, 2008, 03:45:01 pm »
I'm very tempted. I bought some replacement T-Stik joystick sleeves from Franco recently and the workmanship was outstanding.
However, I notice his BYOAC account has been deactivated. Does anyone know why?
polaris
  • veni vidi congai
« Reply #3 on: January 16, 2008, 04:52:49 pm »
that is weird, he only posted this yesterday.
Franco B
« Reply #4 on: January 21, 2008, 03:19:43 pm »
Thanks for the seal of approval guys!
Yeah im here still, my account got deleted somehow  :( :dunno
Aint got a clue how though, Saint said that it must have happened my end but I dont know how it could have unless my account got hacked  ???
Oh well, worse things have happened, its just annoying to lose my Trade Count and I also had a few hundered PMs saved with some valuable information in them  :-[
Anyway, moan over. Just thought I would say these are still availiable. I received the yellow LEDs today and ill get a photo up as soon as I have one wired.
elsie
  • Last login:September 24, 2011, 04:11:35 pm
« Reply #5 on: January 21, 2008, 04:25:23 pm »
Great work!  Any chance you could make up a few of these for the old style Midway 49-way joysticks?  That would be awesome!
Games001
  • Last login:January 13, 2024, 12:44:04 am
« Reply #6 on: January 21, 2008, 05:01:34 pm »
You freakin' ROCK!!!  :notworthy:
These are my next toy of choice.
Franco B
« Reply #7 on: January 21, 2008, 07:01:39 pm »
Hi elsie. Im not sure what the 49 way joysticks look like. Is this one of them?
Looks like it would be no problem. If you can get me some (accurate) dimensions I can write a program for them. If you cannot get accurate dimensions you could always send the stick to me (if you are willing to be without it for a couple of days) and I could send it back with the turned shafts.
Your too kind  :) Feel free to contact me when your ready.
By the way if anyone wants any other colour LEDs then let me know and I can get them in ready. i forgot to take the yellow LEDs with me to work today so I will have to wire one up tomorrow and ill get a picture up then.
elsie
« Reply #8 on: January 21, 2008, 08:08:10 pm »
That is definitely a 49-way, but I'm not expert enough to tell if it is an old Midway 49-way or one of the newer Happ 49-way.  I'd be happy to send the stick to you.  Do you need the whole thing, or just the shaft?
Franco B
« Reply #9 on: January 22, 2008, 01:32:39 am »
Just the shaft will be fine. Ill PM you my address.
Toonces
  • Last login:March 04, 2024, 11:25:24 pm
« Reply #10 on: January 22, 2008, 02:54:31 pm »
PM Sent! Looking forward to getting my Daughter's cab pimped with some nice pink lit sticks!
Toonces
Kaytrim
  • I'm too nice a guy
« Reply #11 on: January 22, 2008, 05:28:25 pm »
Franco,
Can you add the Sanwa JLF and Seimitsu LS-32 shafts to your list?  These would be great additions to my custom sticks.  It might be an idea to add white LEDs to the list then they can be put in any of the bubbletops available.
TTFN
Kaytrim
« Last Edit: January 22, 2008, 05:31:14 pm by Kaytrim »
Franco B
« Reply #12 on: January 22, 2008, 06:16:30 pm »
Toonces, PM replied.
Kaytrim, the JLFs are already available. I should be able to do the Seimitsu's if you can provide me with the dimensions, Im sure a master builder of your caliber can lay your hands on a digital vernier ;)
Yeah I can get some whites if people want them, will you be wanting some in the future? If so Ill order some.
(EDIT: I see what you are saying about the whites, good idea. Sorry was me being dumb)
I got the yellow wired up tonight. Once again my camera doesn't do the colour justice. I cant believe how well those ball tops refract the light  :)
« Last Edit: January 22, 2008, 07:06:59 pm by Franco B »
Daniel B.
  • Last login:May 10, 2024, 05:08:12 pm
  • Lightgun and Point Blank enthusiast
« Reply #13 on: January 23, 2008, 04:55:06 pm »
These really look awesome Franco, I'm still planning on getting them, but money priorities are crazy right now.
DB
Namco Exceleena II (red) | Sega Astro City (needs ms9 monitor work)
Franco B
« Reply #14 on: January 23, 2008, 09:33:38 pm »
No problem Daniel, just give me a shout when you are after some  :)
Thy
  • Last login:November 02, 2012, 03:18:39 am
« Reply #15 on: February 04, 2008, 01:17:28 am »
Random question, do you have any pictures of your Sanwa modified ones in Batton handles as opposed to Ball tops?
Edit: Just looked around and can't find clear bat's anywhere. Know of any places that can do em as well?
« Last Edit: February 04, 2008, 01:46:50 am by Thy »
Toonces
« Reply #16 on: February 05, 2008, 11:30:14 am »
Hi Franco, I don't see it in your howto posts but the pink balltops I just got from lizardlick have a solid cap for the threads. No light can get through to the ball at all. Did you have to drill the balltop so the light could get through? If so, what size bit would you use to avoid damaging the threads?
Toonces
Franco B
« Reply #17 on: February 05, 2008, 11:57:06 am »
Hi Thy, I dont know of anyone that carries them im afraid.
I would make you some but I did look into buying some polycarbonate to machine the ball tops out of before I found the bubble ball tops and it would just be too expensive for small runs.
Toonces
Thats strange Toonces, the ones I bought had an open ended nut in them:
I did buy mine from arcadeshop.de but I thought they would all be the same.
As for drill size a 5mm or 3/16" will be fine.
I've replied to your PM too.
Toonces
« Reply #18 on: February 05, 2008, 12:09:49 pm »
Thanks Franco! I'll give the 5mm bit a try and see if I can get some before and after pics. It's probably a random thing based on whatever the balltop manufacturer has on hand when they cast the balltops.
Toonces
Thy
« Reply #19 on: February 05, 2008, 05:48:25 pm »
PM Sent to you Franco :)
Havok
  • Trade Count: (+17)
« Reply #20 on: February 07, 2008, 01:50:34 am »
I don't suppose you could do a hollow shaft for a U360, with a small cutout at the bottom to allow for a wire to exit, and still mount the magnet on the bottom flush?
Franco B
« Reply #21 on: February 07, 2008, 04:38:31 am »
Yeah no problem, I had already thought about that one.
Can you get me the dimensions for it?
Games001
« Reply #22 on: March 25, 2008, 10:56:33 am »
Franco, are you still making these hollow shafts with light-up options?  If so, what line of sticks are you able to make them for?
Building a new CP and deciding what sticks to go with that can be given hollows.
Thanks.
DJ Infinity
  • Last login:January 19, 2012, 03:48:16 pm
« Reply #23 on: March 25, 2008, 06:36:07 pm »
Do you do Perfect 360's and Super Joysticks? That would be awesome since my source for lighted joysticks is gone. I dare not say the name  ::)
If You Are Going To Meddle At Least Listen
Franco B
« Reply #24 on: March 26, 2008, 11:29:34 am »
Hey guys.
Im sorry but im not going to be able to offer the shafts for the foreseeable future. We have just got too much work on at the moment for me to fit them in. I cant even get them on the machine in lunchtimes etc as the shafts require some special tooling which takes a while to set up.
I have got a few shafts for the JLWs and JLFs left, Ill have to go check.
Sorry guys, I would love to say I can do them but I dont want to promise something that I cant provide. If you want to PM me your requests I can try and squeeze them in if and when I get chance but I cant promise anything.
Im going to make some stainless dust washers up soon though on another machine tool if anyone is interested.
I currently have a program for the washers for the JLW and JLFs but I can do them for any  size washer, plain or grooved, all the same price -  $5 each.
Marak
  • Last login:September 05, 2010, 11:45:05 pm
  • "Look, she's smiling"
« Reply #25 on: March 31, 2008, 09:30:56 pm »
Franco, If you have any JLW shafts left, please let me know. I need 5 of them. Thanks
KSKID
  • Last login:January 02, 2025, 01:37:21 pm
« Reply #26 on: May 09, 2008, 07:26:58 pm »
Do you have any left, I need one also.
« Last Edit: May 09, 2008, 07:45:48 pm by KSKID »
Franco B
« Reply #27 on: May 10, 2008, 03:51:51 am »
You guys have PM  ;)
massive88
« Reply #28 on: August 19, 2008, 03:31:31 pm »
Franco, are you still selling these?  I PMed you some questions.
Franco B
« Reply #29 on: August 20, 2008, 05:43:52 am »
Sorry massive88, I must have missed your PM.
I do have a few for the JLF left. I'm not planning on making any more standard hollow ones though as I'm working on some tangle free versions.
massive88
« Reply #30 on: August 20, 2008, 10:20:30 am »
Your guide in the OP is broken, is there another copy if it somewhere?
What Id like to do is get a color that closest matches the orange color in the Texas text part of my graphic here.
Since you have seen these in action, do you think it would be best with a white top and orange LED?  White top and Red LED?  or Orange top and white LED?
Franco B
« Reply #31 on: August 20, 2008, 01:28:57 pm »
Try [this link].
Its hard to say which single LED/balltop would match your colour scheme as haven't personally tried any orange LEDs/ball tops.
You could try an orange LED with a clear ball top but I dont think it would be too similar to the colour in your font. Then again colours differ from monitor to monitor, LED to LED etc. The only real way to get a close match would be to use an RGB LED.
massive88
« Reply #32 on: August 20, 2008, 03:03:56 pm »
I have no clue on how to use an RGB LED to match colors.  I guess I could try for an orange LED in the white ball, and if it turns out too wrong, I could switch to a white LED.
I guess since I would be potentially switching out LEDs, and since you dont have oranges handy, Ill just go for a shaft from you.  Should we take this to PMs?  Hit me up please.
Luigi
  • Collecting/restoring cabs
« Reply #33 on: August 21, 2008, 05:04:08 am »
Hi there.
I tried those orange LEDs and the color's really great. Unfortunately I cannot make a picture that shows how it looks in reality...it's always too bright. But it definitely doesn't look like the color in "Texas". IMHO this is more red than orange. You could reduce the voltage (or increase the resistor) to make the LED shine "darker".
RGB-LEDs might be a solution but there are only 5mm-LEDs available and I'm afraid they might not fit in to the balltop nor do the 4 connectors go into the hollow shaft.
Or you could use those orange balltops
http://www.arcadeshop.de/Seimitsu-Joysticks-Seimitsu-Ball-LB-39-klar-orange_614.html
and orange LEDs......that should bring the best result.
I have both at home and could give it a try if you like.
massive88
« Reply #34 on: August 21, 2008, 07:50:56 am »
Yeah thats why I was thinking the red LED might be a closer match than the orange.  Maybe a red LED in an orange ball?
If your willing to check it out that would be great.  Im really looking for whatever can give kind of a dark orange (like used here)as opposed to a bright orange (used here).  The matching doesnt have to be perfect.
Perhaps you are right that the orange ball with the orange LED would work better.
Luigi
« Reply #35 on: August 21, 2008, 08:21:15 am »
OK, I will try it: orange ball - orange LED / orange ball - red LED.But keep in mind: if the balltops are not lit, the will still be orange ;)
But, as I said, I didn't find a way to take pictures that come close to reality :(
massive88
« Reply #36 on: August 21, 2008, 08:58:31 am »
I appreciate your help and opinion, and will take it on faith that your perception of reality is accurate, as it is all I have to go on  =D
Franco B
« Reply #37 on: August 21, 2008, 12:09:21 pm »
[cough]
[/cough]
Luigi
« Reply #38 on: August 21, 2008, 02:36:51 pm »
Oh, the socket works? :)
Great...but there's still the problem with the 5mm-LED reaching into the balltop.....I just tried it.....the 4 connectors of the RGB-LED are too big and cannot be set into the hollow shaft (4 in a row, if you get a LED where they are arranged in a rectangle, it might work).
OK, massive88: I think you would be satisfied with the orange balltops and red LEDs. I tried to make photos that let you see the difference but again the result is very poor :(
1) orange LED with orange balltop
2) red LED with orange balltop (a dark reddish orange)
3) red LED with clear balltop
I think (hope) you can see the difference. In real it is far more different than in the pictures.
« Last Edit: August 21, 2008, 02:39:31 pm by Luigi »
massive88
« Reply #39 on: August 21, 2008, 02:45:59 pm »
Heh, yeah its pretty tough to tell from those pics.  But it makes sense to me that the red LED + orange ball would work the best.  I suppose that is what I will go with.
Thank you for your help!
