Author Topic: defender keeps playing over  (Read 2156 times)
g.robert
  • Last login:September 05, 2015, 12:35:59 pm
« on: January 11, 2008, 09:29:11 pm »
My defender has started playing over and over on its own. This has never happened before allthough I have had many other problems with it over the years. 95% of those problems were at the molex connections. Here is whats happening. The game starts two player on its own. The ship sits there until it is hit from one of the aliens. While it shifts to the next player, it does not register a loss of a man. This causes it to play switching player to player over and over.
My gut tells me to pull the game out and start pressing on the connections but this problem is so different from the others and I am also being lazy as it is a hassle to get it out to an area you can work on it. It will not reset with a cycle of power or enter the "set up" menus with the coin door interior buttons. Any ideas.
Thanks, Robert
Level42
Re: defender keeps playing over
« Reply #1 on: January 12, 2008, 08:51:36 am »
You should start checking if the 2 Player start button is stuck.
g.robert
« Reply #2 on: January 12, 2008, 07:21:17 pm »
 :dunno
I powered it off for the night and today it is OK. The start up diagnostic shows all OK but it showed this during the problem as well.
I have had this game for ten years and fixed many of the common Defender problems. This problem is unlike any of the others. No buttons are stuck. Even if it was, it was not loosing a man once shot like a normal play would. This indicates to me not a wiring or input issue but something else. Why would it play different?
I am hoping someone has experienced this exact problem and can identify the likely cause.
Thanks, Robert
vintagegamer
  • Last login:October 26, 2025, 06:07:31 pm
  • Seasoned Arcade Survivor.
« Reply #3 on: January 13, 2008, 03:21:47 pm »
What is it about this game that it is chock full of bugs?  I know noone ever expected the games to live this long to begin with, but Defender seems to have alot more probs than alot of the other cabs out there.  Is this common across all Williams cabs?
VG
g.robert
« Reply #4 on: January 13, 2008, 06:08:18 pm »
The three most common problems are:
1. power supply
2. connection at molex connector
3. Ram / Rom chip bad or poor connection between chip and base
Othen than those, the games run fine for many years. I wish I had an idea about my new problem. For now all is well.
Thanks, Robert
RayB
  • I'm not wearing pants! HA!
  • There's my post
    • RayB.com
« Reply #5 on: January 17, 2008, 12:02:18 pm »
VG
Probably. Power problems tend to fry chips.
NO MORE!!
