Author Topic: Anyone using an Xarcade Joystick? Interested in skins?  (Read 9196 times)
Cadder
  • Last login:February 15, 2008, 09:58:10 am
« on: January 09, 2008, 06:35:54 am »
Greetings, users.
Over the past couple of years I have been "tinkering" with a Mame box that I've never quite got around to finishing the hardware for... but that's another story. Meantime, I've been using Doscad/Wincab Jukebox on the same machine, and unsurprisingly, the machine gets used more as a jukebox than a MAME box.
However, I have done the hard part - and that is configuring my dual-joystick Xarcade controller to control DWJ in a coherent fashion, and even gone so far as to create a skin (OK, it's not created from scratch, it's a mod of the "main" skin).
I was just wondering if anyone else is using this type of controller?
I'm presently working on a CD-based version of the same skin (this will need work from the ground up). If anyone is interested, I'll upload the skins when they're done.
Cad nominatim, CAD per professio, cad per vis.
carnid
  • Last login:September 17, 2012, 10:29:53 pm
Re: Anyone using an Xarcade Joystick? Interested in skins?
« Reply #1 on: January 10, 2008, 10:00:59 am »
I am in the process of completing the finishing touches to my Mameroom cabinet with which I have used the x-arcade xxl panel.  I have read a lot of negatives on this board with regards to the controller, however I have no complaints, however still very much an amateur and have no other controllers to compare it to.  Anyway - if you do have skins or themes I would definitely be interested.  I was thinking of making my own for Maximus Arcade which is what I use for my frontend.  What software do you use for the jukebox - I have a ton of songs on itunes and would be interested in using my cab for this also?
MyCatSucks
  • Last login:September 25, 2023, 03:57:15 pm
« Reply #2 on: January 26, 2008, 04:08:11 pm »
I thikn I would be interested in skins. I have not received my XXL yet but I did have the intention of painting it or getting a skin on it.
Cadder
« Reply #3 on: January 31, 2008, 11:10:33 am »
ummm.. maybe I should've been more specific.
I'm happily using DWjukebox (since this IS posted in the Dos/Wincab forum...)... and I was referring to skins for that particular app configured for an X-arcade, not skinning the Joystick itself.
