Author Topic: Is there a way to wire a joystick so . . .  (Read 1542 times)
The_Roker
  • Last login:November 08, 2003, 02:45:52 pm
« on: May 15, 2003, 01:33:35 am »
a button has the identical function as another, for instance:
  X  Y  L
  A  B  R
L
I'm trying to devise a setup so I will be able to use a joystick (X-Arcade) with my ported Neo games, in essence making up for the lost button by transferring an identical L button, while also retaining the Capcom setup.
kspiff
  • Last login:February 02, 2016, 09:15:36 pm
  • Love of the game, baby.. love of the game..
Re:Is there a way to wire a joystick so . . .
« Reply #1 on: May 15, 2003, 01:55:12 am »
Wire the connection from the NO tab for both buttons into the same spot on your encoder.
k-spiff
armad1ll0
  • Last login:March 28, 2012, 12:24:57 pm
  • The player and the builder!
    • Modeverything
« Reply #2 on: May 15, 2003, 03:47:47 am »
yup, just wire one to the other's contacts.
Simple right? imagine it as a the grounds go to both and the positive is split to a Y and goes to both "L" buttons.
The_Roker
« Reply #3 on: May 29, 2003, 05:35:19 am »
So they both have to have the same ground?
And the same wire for the other contact?
Rocky
« Reply #4 on: May 29, 2003, 10:22:30 am »
That's right.  That way either switch can close the circuit and send the keystroke to the encoder.
Rocky
shmokes
  • Don't tread on me.
    • Jake Moses
« Reply #5 on: May 29, 2003, 10:48:58 am »
But this would be a non-issue if you're chaining all of your grounds together in one big loop.....................................................right?
Best Kid iPad Apps
Tiger-Heli
    • Tiger-Heli
« Reply #6 on: May 29, 2003, 11:10:27 am »
I don't think X-Arcade uses a common ground for their encoder.
Your easiest option is to see http://www.xgaming.com/htm/programming.shtml and program the lower left button from C to X and the P2 lower left button from "Close Brace" to Q.
Alternately, you could wire the C button to the same inputs on the circuit board as the X button, but this would be more work and void your warranty.
Hoe
  • Last login:September 05, 2004, 01:17:09 pm
« Reply #7 on: May 29, 2003, 08:26:41 pm »
I just looped a wire going from L to the other L (like how one would loop grounds).
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #8 on: May 30, 2003, 03:38:09 am »
I thought it didn't make a difference if the split was at the encoder, a Y before the switches, or as a daisy chain.  Aren't the following 3 schematics equivalent?
   _____b1____gnd
eL/
  \_____b2____gnd
     ___b1____gnd
eL__/
    \___b2____gnd
      b1______gnd
eL___/\
       \_b2___gnd
Robin
Knowledge is Power
