Author Topic: Exit with controller using Mala and Jnes ?  (Read 4070 times)
Xali
  • Last login:August 02, 2009, 01:06:35 pm
    • www.xazax.com
« on: January 07, 2008, 04:44:38 pm »
Is it possible to use a controller button to exit the game in Jnes emulator so he goes back to the Mala gamelist ??
In Nestopia it works but i can`t figure it out how i can do the same with Jnes ??
Turnarcades
  • Craig @ Turnarcades
    • Turnarcades
Re: Exit with controller using Mala and Jnes ?
« Reply #1 on: January 07, 2008, 05:28:06 pm »
This is a familiar frontend/emulator problem. A lot of emulators stick with the norm of using 'escape' to exit by default, and only a few allow assigning buttons to key functions like exiting the emulator.
Similarly, a lot of emulators do not like using the default mame keys for inputs, so whereas most people assign i-pac configs for each emulator, I reassign all of my emulators (including mame) to 'regular letter keys, assuring no input conflicts across the emulators.
Xali
    • www.xazax.com
« Reply #2 on: January 08, 2008, 01:42:38 am »
I use Nestopia for now but i hope the fix something soon in Jnes to configure the controls the same as in Nestopia  :)
I don`t know if Joytokey will work ?
Turnarcades
    • Turnarcades
« Reply #3 on: January 08, 2008, 07:20:18 am »
Joytokey is good. If you use a PS2-style pad you will have spare buttons available to assign Escape, P (pause) and 'insert coin' toas well as the usual 6 fire buttons.
Xali
    • www.xazax.com
« Reply #4 on: January 08, 2008, 12:35:00 pm »
I use the original ps2 controllers so i am going to try it.
Tnx for the help so far :)
