Author Topic: Mala Sound Issue  (Read 2516 times)
koolmoecraig
    • My Intervention
Mala Sound Issue
« on: January 07, 2008, 05:13:58 am »
I set up some .wav files to work with Mala.
The sounds work when I select the game and when I exit Mala but they will not sound when I page through the different games.
I imagine this has to do with the fact that I have the buttons wired into an IPAC and those work fine because it is a "keyboard".  The joystick motion sounds are not working because I am using a U360 via USB.  Basically keyboard actuated sounds work, joystick actuated do not.
Any idea how to fix this?
loadman
  • Moderator
    • MaLa
Re: Mala Sound Issue
« Reply #1 on: January 07, 2008, 04:28:10 pm »
Have you trried playing with this setting (see pic)
koolmoecraig
    • My Intervention
« Reply #2 on: January 08, 2008, 12:55:21 am »
Now why would I have tried that?
Now if I could just figure out that Q*bert map
