Author Topic: xp mamewah wincab loading probs  (Read 1479 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: January 06, 2008, 10:49:45 am »
right! i have set it up a treat ! the pc powers up to mamewah as the shell in 10 seconds !! but on exit i want it to load wincab... if i press '2' 'exit mamewah' it loads wincab but i want to be able to press esc and get wincab up.
also how to i get back to mamewah after wincab as there is no windows no nothing once wincab is shut as mamewah was the shell, i don't want to have to do this the windows way !
Re: xp mamewah wincab loading probs
« Reply #1 on: January 08, 2008, 05:52:17 am »
Edit your Mamewah ctrlr file (probably \mamewah\mamewah.cfg or \mamewah\config\mamewah.cfg) and set:
EXIT_TO_WINDOWS "DIK_ESCAPE"
Perhaps launch WinCab as an external app from Mamewah (ie not quitting Mamewah) and then quitting WinCab will return to Mamewah?
david656
  • Big Man!
« Reply #2 on: January 08, 2008, 12:05:06 pm »
thats great thanks :D and i'd love to do it that way but errmmm how !
« Reply #3 on: January 09, 2008, 07:33:03 am »
Good question.... ;-)
1) In your (Mamewah) mame.ini file, set 'general_app_commandlines c:\wincab\wincab.exe' (or whatever)
2) Back in your Mamewah ctrlr file, set LAUNCH_APP_1 "DIK_ESCAPE"
Note if you use Escape above, you will need to remap EXIT_TO_WINDOWS to something else.
Also note this will only work when your Mame list is selected, UNLESS you repeat step 1 for each of your emulator.ini files.
Hope that helps!
