Author Topic: Freebox Error Help  (Read 2616 times)
gonzo90017
Freebox Error Help
« on: January 01, 2008, 03:46:13 pm »
Everytime I try to start Freebox I get this error.
JackTucky
  • Last login:January 04, 2021, 12:00:58 pm
  • Soon I will post that I am a triathalete
Re: Freebox Error Help
« Reply #1 on: January 01, 2008, 06:02:46 pm »
Have you run the config3 program?  Are you just testing?  You need to have at least 2 artists/albums for it to work.
Other things could be directories have changed since you last ran config.
You can try posting on the freebox forums.
http://www.freeboxjukebox.com/Forum/
=J
Well, that's where we go a-ridin' into town, a whampin' and whompin' every livin' thing that moves within an inch of its life. Except the women folks, of course.
Barry Barcrest
  • Last login:November 09, 2021, 09:54:17 am
  • Simple Plan
    • E-Touch Jukebox
« Reply #2 on: January 01, 2008, 09:02:25 pm »
What version of freebox are you using? If you are using V3 demo did you recreate your libraries? The V2 ones will not work with V3. How many albums show up in the config for the audio library? When exactly do you see the error? Does freebox play a track first or does it not even load.. You will get a quicker response on the freebox forums, however iwll need a little more info that what you posted.
gonzo90017
« Reply #3 on: January 02, 2008, 12:00:04 pm »
I'm using version 2.20. It was working fine. Then I transfered some mp3 from some backup dvd's and I generated the library. Now I get that error everytime I try to launch it. I tried uninstalling and installing it again but I get the same results.
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #4 on: January 02, 2008, 05:22:26 pm »
You might need to delete the freebox folder it self before reinstalled, since config files normally not deleted (if they got messed after the update?)....
Otherwice I guess 2.20 is now unsupported... hence it free.
« Last Edit: January 02, 2008, 05:31:19 pm by Space Fractal »
Barry Barcrest
  • Simple Plan
    • E-Touch Jukebox
« Reply #5 on: January 02, 2008, 11:35:46 pm »
demo?
Space Fractal
  • Space Fractal
    • Space Fractal
« Reply #6 on: January 03, 2008, 04:37:16 am »
hehe, I forgot to tell about the new update since previous versions is allways unsupported. Sorry, Barcrest. He just tell v2.2 actuelly worked fine as it was.
