Author Topic: TV making popping and sparking noises  (Read 5231 times)
david656
  • Last login:June 01, 2017, 10:06:24 am
  • Big Man!
« on: January 01, 2008, 01:07:34 pm »
hi guys,
got a TV of a family member that has been sitting in a shed for 6 months, i have had it for about a hour sitting in the warm and decided i could probably plug it in ! well i plugged it in with the standby light on and it was fine, came back to my pc and thought whats that popping noise ! and it was the TV so i rushed and unplugged it.... is it bust or ok? do i plug it back in?
would br grateful  of all the help you can give me
StephenH
Re: TV making popping and sparking noises
« Reply #1 on: January 01, 2008, 01:35:35 pm »
I would NOT plug it in again until you get it fixed.   There is probably some bad parts in there somehere, perhaps capacitors, transistors, or the flyback.
grantspain
« Reply #2 on: January 01, 2008, 01:39:05 pm »
the tv would need 24 hours to acclimatise and you would probably have to clean around the anode of the tube and the anode itself-first discharge the tube and use a very light cleaning liquid on a cloth to clean off any dust and moisture,do not spray onto the tube itself
i doubt any damage has been done
david656
  • Big Man!
« Reply #3 on: January 01, 2008, 01:52:46 pm »
grantspain ! long time no see :D
humm well as you will remember im know 16 ! and its happening january to febuary in school im building a moon patrol cab from scratch !
so like i say this TV 'DID' work...... i really don't want to start poking about .... if i leave it plugged in over night with the power off so its earth i presume thats fine, but will i be able to plug it in tomorrow and be able to watch some crappy day time TV?  Do i really need to poke about?
grantspain
« Reply #4 on: January 01, 2008, 02:36:48 pm »
you may just get away with allowing the tv to get to room temperature,see how it goes tomorrow-if you get big blue sparks then you will need to do the cleaning process
david656
  • Big Man!
« Reply #5 on: January 01, 2008, 02:52:47 pm »
BIG BLUE SPARKS !!!!  :hissy:  this isn't the terminator's 4th arrival is it ?!?!?!?!?!?
well the sparking sounded deep with in and i didn't see any and certainly didn't hang around waiting for them ! so hopefully i turned it off before major damage was done... we will see tomorrow
thanks for info
david656
  • Big Man!
« Reply #6 on: January 02, 2008, 06:37:32 am »
ok guys the TV is as flat as a pancake ! plugged it in and well it go's dong so the power is going into it but the standby light doesn't light and the tv doesn't come on so its nackered ! and objection to its newer brother
http://www.argos.co.uk/static/Product/partNumber/5291814/Trail/searchtext>TV.htm
may be getting taht one as a replacement
