Author Topic: Gauntlet Legends CPU Specs for MAME to run smoothly?  (Read 5789 times)
« on: December 30, 2007, 10:10:40 pm »
Hi,
I was wondering what system specs are necessary for Gauntlet Legends to run smoothly in MAME.  I currently have an AMD 64 X2 4000+ (2.10 GHz) and it runs SUPER SLOW.
Also, while I am on the subject of games running slow, some of my 3D games' audio stutters which slows it down considerably.  (I know MAME is mainly CPU based, yada yada yada).  I have Zinc to solve the problems of the Tekken games, but saw the same pattern of the stuttering audio in many newer games.  One in particular, Gradius 4.
I turned down my bitrate from 48000 to 24000 in MAME.  Still does not help.  Any suggestions?
Thanks in advance!
~ DeLuSioNaL
SGT
  • Last login:May 31, 2025, 10:10:32 pm
Re: Gauntlet Legends CPU Specs for MAME to run smoothly?
« Reply #1 on: December 31, 2007, 12:05:25 am »
A Core 2 Duo overclocked at 4ghz will barely run it with Mame .120u1:
http://forum.arcadecontrols.com/index.php?topic=72776.0
If you skip on down in the thread, you will see that 64 bit Mame running (obviously) under a 64 bit operating system does substantially better.
The Dreamcast version of Gauntlet Legends seems to run well under nulldc:
http://forum.arcadecontrols.com/index.php?topic=74315.0
« Last Edit: December 31, 2007, 12:08:02 am by SGT »
