Author Topic: sanyo 20-ez donkey junior monitor issue  (Read 2922 times)
robotype
  • Last login:November 23, 2012, 05:54:42 pm
SirPeale
  • Green Mountain Man
Kevin Mullins
    • Me on Myspace
Re: sanyo 20-ez donkey junior monitor issue
« Reply #2 on: December 30, 2007, 01:22:18 pm »
Looks kinda like a bit of foldover..... might try reducing the vertical size/height.
SirPeale
« Reply #3 on: December 30, 2007, 03:05:24 pm »
It's DEFINITELY foldover, but it's caused by old caps.  Once they're replaced, the screen will adjust to the edges again.
Kevin Mullins
    • Me on Myspace
« Reply #4 on: December 30, 2007, 04:14:49 pm »
Yeah, the rest just looks so good that it was hard to tell.   :cheers:
robotype
« Reply #5 on: December 30, 2007, 11:01:19 pm »
it would be great to know exactly which cap does this...anyway thank you!
Kevin Mullins
    • Me on Myspace
« Reply #6 on: December 31, 2007, 12:01:00 am »
Well, in my opinion.... you can figure out exactly which cap may be bad and causing a particular problem with the right equipment..... but when ALL of the caps are probably going on twenty plus years old... you might as well just do a cap kit otherwise another one will probably go bad down the road a bit and just cause a different problem.   ;)
