Author Topic: minipac problem  (Read 1788 times)
fdm
  • Last login:December 26, 2008, 04:18:52 pm
minipac problem
« on: December 27, 2007, 03:24:21 pm »
I just finished wiring up my control panel and I am trying to test/program my minipac interface card. If I have the 40 pin IDE connector connected to the minipac card when I try to program it using the Winipac application I get "failed to program device". If I disconnect the 40-pin connector it will successfully program it, but I obviously cannot test it.
If I have the device manager up and plug the minipac into a USB port on my PC WITHOUT the 40-pin connector on it, XP installs drivers and several new devices show up such as a HID keyboard, USB composite device, etc.
When I do the same WITH the 40-pin connector connected, the only device that shows up is an unknown USB device.
I've connected a keyboard via the ps/2 pass-through connector on the minipac and when I go into test mode it detects the keys pressed on the keyboard but none via the controls wired into the 40-pin connector.
Does this mean I have a wiring problem on one of my controls? If so, what should I look for, a missing ground, etc? I don't want to disconnect all of my wiring to troubleshoot if I don't have to.
Do I have a defective minipac?
Or am I just doing something fundamentally wrong?
fdm
Re: minipac problem
« Reply #1 on: December 27, 2007, 04:24:01 pm »
I figured out my problem. It was a bad microswitch on one of the buttons. I found it by disconnecting all of the wiring and connected each device testing after each one.
Akuma
  • Last login:October 06, 2011, 07:51:30 am
  • lp, lp → lk, sp
Re: minipac problem
« Reply #2 on: December 27, 2007, 04:29:42 pm »
in exactly 59 minutes and 40 seconds : ) good job
