Author Topic: how do I degauss a hantarex polo 3 monitor?  (Read 4843 times)
Jimbo
    • Wood Finishes Direct
« on: December 26, 2007, 03:25:19 pm »
I have a 21" polo/3 from hantarex, and tried switching off and on (thought that would work) but it seems it doesn't degauss unless its switched off for a minute or so...  Any clue as to how I might get this to work on quick switch off/on... or is there another way?
grantspain
Re: how do I degauss a hantarex polo 3 monitor?
« Reply #1 on: December 26, 2007, 03:44:23 pm »
the only way to do want you want is to have a manual degauss switch,i do not really understand why you need this as once a monitor degausses the picture should be fine unless you have a strong magnetic force close by.
the degauss circuit works via a sort of thermistor(ptc component) that only operates from cold start
Jimbo
« Reply #2 on: December 26, 2007, 03:55:39 pm »
Hi there
I have just put together my rotating monitor setup, hence the need for a degauss each time I rotate the monitor.  Currently, switching off and on doesn't seem to trip the degauss, unless I leave the monitor off for a minute or longer (like you said - a cold start).  Do you have any pointers on building a manual degauss switch (say attached to a pushbutton)?  Thanks again.
grantspain
« Reply #3 on: December 26, 2007, 04:08:17 pm »
hantarex could probably tell how to mod the chassis but i reckon your best bet is to get a manual degauss wand as then you don't have to mess with anything-look at degaussing on ebay,you can get them for $10 + shipping
i understand why you need this with a rotating tube
Jimbo
« Reply #4 on: December 26, 2007, 04:19:27 pm »
cheers for your help, I'll check ebay out  :cheers:
grantspain
« Reply #5 on: December 26, 2007, 04:23:11 pm »
where abouts are you in kent,i am originally from maidstone btw
Jimbo
« Reply #6 on: December 26, 2007, 04:27:12 pm »
Folkestone :)  I lived in Maidstone for a couple of years.  The only thing Folkestone is missing is a Maplins... still, a B&Q just opened round the corner from my house, so I can't complain too much! :P
grantspain
« Reply #7 on: December 26, 2007, 04:39:43 pm »
i used to frequent folkestone,mainly for the sunday market and a nice coffee at kens(i think its called the hillside cafe)-a very long time ago though :-\ and a bit different than marbella :)
Jimbo
« Reply #8 on: December 28, 2007, 11:20:23 am »
Before I go buy one of those degaussing wands... do they work if there's glass in the way?  I have 6mm tinted toughened safety glass about an inch in front of the monitor screen.  Also, how long should I have to wave it before the colours are back to normal?
Thanks again
p.s.  The sunday market is no more!  All the land is being converted into posh housing and a marine afaik! :)
Kevin Mullins
    • Me on Myspace
« Reply #9 on: December 28, 2007, 11:26:48 am »
Keep in mind that there is somewhat of a technique that you must use to properly degauss the monitor even with a degauss wand or coil.... and you would still have to do this EVERY time you rotated the monitor.
The Nanao monitors used to have a seperate pushbutton degauss circuit, I wonder if something like that could be incorporated into your design.
grantspain
« Reply #10 on: December 28, 2007, 05:55:41 pm »
it will work through glass,basically all you do is start close to the tube and move away using a circular motion until the gaussing goes(a few seconds should suffice)
