Author Topic: Atari Cone/Vulcano/Cherry buttons LED's: How to replace them ?  (Read 2026 times)
Level42
« on: December 15, 2007, 06:23:56 pm »
I have two of these for my Centipede. However, I'd like to repace the LED's as they are very dim. One is worse than the other. Anyway, they seem to be soldered on the side of the metal strips that are out of reach for a soldering iron ?
And I don't see a way to disassemble the thing ?
SirPeale
  • Green Mountain Man
Re: Atari Cone/Vulcano/Cherry buttons LED's: How to replace them ?
« Reply #1 on: December 16, 2007, 02:14:58 pm »
It's tricky.  You basically have to remove the rivets, fix it, then re-rivet it (or an equivalent).
Level42
« Reply #2 on: December 17, 2007, 11:25:01 am »
OK, think that means using the dremel.....
Small bolts should work right ?
[Edit : turned out that was not needed: Check out how I did it here:
http://forum.arcadecontrols.com/index.php?topic=63654.msg772566#msg772566]
« Last Edit: December 19, 2007, 03:05:36 pm by Level42 »
